Using the Second Derivative Test
The discussion revolves around finding relative extrema using the second derivative test for the function H(x) = x * ln(x). Participants are exploring the application of the second derivative test and the necessary conditions for identifying critical points.
  • Participants discuss the calculation of the first and second derivatives, questioning the correctness of H''(x) and how to find relative extrema. There are inquiries about solving for critical points and the implications of the second derivative test.
The conversation includes attempts to clarify the conditions for relative maxima and minima based on the second derivative test. Some participants express confusion regarding the interpretation of H''(x) and its relationship to determining relative extrema, leading to a mix of interpretations about the test's application.
There is a noted uncertainty about the definitions and application of the second derivative test, with references to textbook guidance that may be conflicting. Participants are also grappling with the implications of critical points and the behavior of the function at those points.
BuBbLeS01
Find all relative extrema using the second derivative test for H(x) = x * lnx
H'(x) = (1 * ln x) + (x * 1/x) = lnx + 1
H''(x) = 1/x + 0
Is H''(x) right? Then I am having trouble finding the relative extrema from the second derivative test?
h''(x)=1/x
Okay so how do I solve for the relative extrema?
just try graphing the function and go from there. i don't remember what the second derevative test is, its been a long time. don't you have to set denominator =0 and solve x?if so x=0.
Set H'(x)=0 and solve for x to find the critical points. For each critical point x test the sign of H''(x) to see if it's a max or a min.
H"(x) = 0
Set H'(x)=0 not H''(x)=0. Critical points are where H'(x)=0.
How do you solve lnx + 1 = 0 for x?
would it be...
lnx + 1 = 0
lnx = -1
x = e^-1
Then I would plug that into H" = 1/x, H" = 1/(e^-1) = e > 0 so its a relative max?
That's almost all exactly correct, except the final conclusion. How can you say H''(x)>0 at a critical point means it's a max?? Don't you have like a textbook or something?
H''(e^-1) > 0 means a relative max...thats what our book says to write? What do you mean? Is that wrong?
Either you should throw away your textbook or you should read it more carefully- that's exactly backwards!
Yea, for the second derivative tests things are sort of backwards.
If f"(c)<0, then x=c is a relative maximum.
If f"(c)>0, then x=c is a relative minimum.
f f"(c)=0 or undefined, then the second derivative test is inconclusive.
