How Do You Calculate the Initial Velocity of a Projectile?
  • Context: Undergrad
  • Thread starter Thread starter jennypear
    Projectile Velocity
The initial velocity (Vo) of a projectile fired at an angle of 28.0 degrees from a height of 46.0 meters can be calculated using the equation (Vfy)^2 = (Voy)^2 + 2 * Ay * (delta Y). In this case, the vertical component of the initial velocity (Voy) is determined as 0.47Vo, and the final vertical velocity (Vfy) is 1.95 times the vertical component. The correct calculation yields an initial velocity of 37.9 m/s, although the user initially arrived at an incorrect conclusion, indicating the need for careful application of kinematic equations.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of trigonometric functions, specifically sine
  • Basic grasp of gravitational acceleration (9.8 m/s²)
  • Review the derivation of kinematic equations for projectile motion
  • Study the effects of launch angle on projectile trajectories
  • Explore the relationship between initial velocity and maximum height
  • Learn about energy conservation in projectile motion
Students studying physics, educators teaching projectile motion, and anyone interested in solving real-world problems involving kinematics.
jennypear
projectile is fired w/an angle of 28.0degrees above the horizontal and from height 46.0m agove the ground. the projectile strikes ground w/a speed of 1.95xVo. Find Vo
I started using the eqution
(Vfy)^2=(Voy)^2+2*Ay*(delta Y)
Voy=Vosin(theta)=.47Vo
Vfy=1.954*Vosin(theta)=.92Vo
(.92Vo)^2=(.47Vo)^2+(2*-9.8*-46)
Vo=37.9
but my answer is wrong and I can't think of another way to answer the problem...Any ideas?
Thanks for your time!
21K
9K
11K
