Finding the Momentum-Space Wave Function for a Harmonic Oscillator Ground State
The problem involves finding the momentum-space wave function, \Phi (p,t), for a particle in the ground state of a harmonic oscillator and determining the probability of measuring momentum outside the classical range. The context is quantum mechanics, specifically related to harmonic oscillators.
  • Participants discuss the integration of the wave function and the evaluation of Gaussian integrals. There is an exploration of the classical range of momentum values based on energy considerations. Questions arise about the integration variable and the bounds for kinetic energy and momentum.
Some participants have provided guidance on evaluating integrals and clarifying the relationship between classical and quantum values of momentum. There is an ongoing exploration of the correct limits for integration and the definitions of terms used in the discussion.
Participants note confusion regarding the classical values of momentum and the implications of the ground state energy. There is a mention of homework constraints, as one participant indicates they have already submitted their work.
Rahmuss
Find the momentum-space wave function, [tex]\Phi (p,t)[/tex], for a particle in the ground state of the harmonic oscillator. What is the probability (to 2 significant digits) that a measurement of [tex]p[/tex] on a particle in this state would yield a value outside the classical range (for the same energy)? Hint: Look in a math table under "Normal Distribution" or "Error Function" for the numerical part -- or use Mathematica.
(Problem 3.11 - Intro to QM, 2nd Edition, by Griffiths)
[tex]\Phi (p,t) = \frac{1}{\sqrt{2\pi \hbar}} \int^{\infty}_{-\infty} exp[{\frac{-ipx}{\hbar}}] \Psi (x,t) dx[/tex]
The above equation is the only one that I know should be right. That being said, here is what I've tried so far:
[tex]\psi_{o} (x,t) = (\frac{m\omega}{\pi \hbar})^{\frac{1}{4}} exp[{\frac{-m\omega x^{2}}{2\hbar}}] exp[{\frac{-iE_{o}t}{\hbar}}][/tex]
With [tex]E_{o} = \frac {\hbar \omega}{2}[/tex]
[tex]\psi_{o} (x,t) = (\frac{m\omega}{\pi \hbar})^{\frac{1}{4}} exp[{\frac{-m\omega x^{2}-i\hbar \omega t}{2\hbar}}][/tex]
[tex]\Phi (p,t) = \frac{1}{\sqrt{2\pi \hbar}} \int^{\infty}_{-\infty}exp[{\frac{-2ipx -m\omega x^{2} -i\hbar \omega t}{2\hbar}][/tex].
And if that's right, then I'm not sure how to integrate that. Then after I get what that equals (lets call it ANS), then to find the probability outside the classical value, I need to square [tex]\Phi (p,t)[/tex] right? I'm guessing that I would have something like:
[tex]2\int^{\infty}_{ClassicalValue}ANS dp[/tex]
I'm taking 2 times the integral because I'm guessing since it's an even function that I could take the negative classical value to -infinity as well; but it would equal this. But I'm not sure what to use for the classical value because of how the problem is worded. Am I on the right track?
Yes, on the right track.
To evaluate the integral, first take any constants out (note: you've omitted the integration variable), then use any tricks you may know for evaluating Gaussian integrals.
To find the classical range of values of momentum, assume the total energy of the classical oscillator is some E. What are the maximum and mimimum values of the KE? That leads to the classically allowed values of p in terms of E. Now make E=ground state energy of quantum HO.
Gokul43201 - I'm not sure I know what you mean by the "integration variable". You mean, what we're integrating with respect to? I have that in there as [tex]dp[/tex].
So :
[tex]E = \frac{1}{2}kx^{2}[/tex]
[tex]KE = \frac{1}{2}kx^{2}sin^{2}(\omega_{o}t + \phi)[/tex]
[tex]PE = \frac{1}{2}kx^{2}cos^{2}(\omega_{o}t + \phi)[/tex]
Would suggest at [tex]x = 0[/tex] would have a minimum and where [tex]cos^{2}(\omega_{o}t + \phi) = 0[/tex] would be another minimum.
For a max we have [tex]x = \infty[/tex] with [tex]cos^{2}(\omega_{o}t + \phi) = 1[/tex].
[tex]p = m\frac{dx}{dt}[/tex]. So I guess I'm not quite sure what you mean. I'm probably just being an idiot here and it should be very simple.
I was talking about the previous integral - the one for [itex]\Phi(p,t)[/itex].
So :
We are looking for the bounds of the KE. Since [itex]0 \leq sin^2 \theta \leq 1[/itex], the KE is bounded by 0 and E. Now we plug in the E for the ground state of the quantum harmonic oscillator, which is ...?
Since KE = p^2/2m, the bounds on KE tell us the bounds on p for the classical oscillator.
[tex]E_{n} = (n + \frac{1}{2})\hbar \omega[/tex]. And so the ground state for the QHO is:
[tex]E_{o} = \frac{\hbar \omega}{2}[/tex].
So for our integral we're looking for :
[tex]2*\int^{\infty}_{\frac{\hbar \omega}{2}} (ANS)^{2} dp[/tex]. Is that right?
Almost!
[tex]E_{o} = \frac{\hbar \omega}{2} = \frac{p_{_{Cl}}^2}{2m}[/tex]
[tex]\implies p_{_{Cl}} = \sqrt{m\hbar \omega}[/tex]
Oh, so:
[tex]2*\int^{\infty}_{\frac{p^{2}}{2m}}(ANS)^{2} dp[/tex].
Thank you very much for the help on this.
P.S. What does the subscript "Cl" represent on [tex]p_{Cl}^{2}[/tex]?
Rahmuss said:
Oh, so:
No, you are integrating over momenta, not energies. So, the lower limit of the integral needs to be p_{Cl}.
That's the classical upper bound on the momentum.
Oops. I already turned my homework in. Oh well. Live and learn. Thanks again for the help.
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 16 ·
