Thread Closed
how to convert DC to AC??
Share Thread Thread Tools
Oct24-07, 07:44 AM   #1
how can i convert DC to AC from a battery(any voltage) for a transformer...?????
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Oct24-07, 07:55 AM   #2
You need what is called an inverter. It takes the DC voltage and turns it into AC. It would be very helpful to know what you are wanting to do with this as there are a variety of parameters that can affect your choice of inverter depending on the voltage and purpose. Some cheap inverters for getting 120/220 mains AC from a battery or battery bank do not make pure sine waves and can destroy microwaves, computers, etc.
Oct24-07, 08:05 AM   #3
for transformers i have to input it with AC only....but how can i convert it from a battery...i require low voltage AC(may 6-12V) for the transformer ...
Oct24-07, 08:26 AM   #4
I will try to make the questions you ned to anwer clearer.
First, you need 6-12 volts FROM the transformer. What voltage, AC frequency and how many watts do you need going into it?
Now, the second part of myquestion again: What are you going to DO with this voltage? What frequency of AC is required for the transformer ANDthe circuit it is driving? How sensitive is the driven circuit to the waveform of the AC, e.g. audio circuits will click and hum, computer circuits may just die, clock circuits will not keep time, etc if the waveform is not a fairly close to a sine wave....
Oct24-07, 09:12 AM   #5
just step down the 120vac to 6-12vac. is that possible or your main supply is battery (small device?)
otherwise just use a digital/analog converter to create your sine wave, go through an amplifier (with supply +-15v) to amplify amplitude
Jul26-08, 02:09 PM   #6
sir i want to convert (12v DC )to (12v AC) plz tell me the name of converter or sujjetiojn that can i build it or not ... plz guide me kashif
Aug10-08, 03:53 PM   #7
Mechanically...take a 12vdc motor and drive a 12vac alternator.
Electrically...build an invertor.
To make it smooth...add 60Hz band pass filter.
Aug11-08, 11:34 AM   #8
Mentor
Quote by hajirandi View Post
This is the kind of circuit that is being suggested to you, a "Power Inverter":
http://en.wikipedia.org/wiki/Power_inverter
Sep17-09, 03:56 PM   #9
hello iam trying to invert 120 dc to 120 ac, have a generator exciter that puts out 120 dc only, would like to invert to 120 ac to run small tools thanks anthony
Sep17-09, 05:08 PM   #10
Mentor
First google hit for "120vdc inverter": http://www.novaelectric.com/dc_ac_in...120cabinet.php
Sep18-09, 09:17 PM   #11
russ thanks for reply, the unit i saw is way too expensive , is there a simple circuit i can build to invert 120 dc to 120 ac thanks anthony
Sep19-09, 01:04 AM   #12
Mentor
Quote by fest777 View Post
What experience do you have working with voltages above 60V? And what experience do you have designing and building equipment to comply with Underwriters Laboratories (UL) standards?
Sep19-09, 12:31 PM   #13
very limited, iam very good a reading schematics and building things yet i don not have an electrical engineers degree. , any good ideas would help
Sep19-09, 12:56 PM   #14
If you have a 6V or 12V battery and you only need a little current (< 1A), you could always pick up a solidstate radio vibrator. They run about $25 US.
Sep19-09, 07:25 PM   #15
Recognitions:
Some portable power tools used on 230 volts use DC series wound motors on AC.
The field coil is in series with the rotor winding.
Not sure if this is the same with 110 volts, but if it is, then the 120 volts DC will work OK with such power tools.
You can easily check. With the tool unplugged, take out the screws and look at the wiring. If it goes through the switch, through the field coil, through another field coil then to one of the brushes on the rotor and from the other brush back to the power cable, then it is a series would motor.
If it has a speed control in the trigger this probably depends on it getting AC, so the tool would be unsuitable for running on DC.
Dec1-10, 03:12 PM   #16
The simplest, cheapest way I can think of is to use a DC relay that will operate at your supply voltage and wire one of its NC (normally closed) contacts in series with the coil and in series with the transformer primary. This will not give you a 60 Hz sine wave but you will have AC at the secondary of the transformer.
Dec4-10, 02:57 AM   #17
hello can anyone tell me about why we use ac at particular performance and not use dc.where dc is required what is its reason of must use of dc,and similarly for ac?
Thread Closed
Thread Tools
Similar Threads for: how to convert DC to AC??
Thread Forum Replies
how to convert from hex to dec ? General Math 6
Convert mol/L to kg/m3 Classical Physics 3
How to convert C-12 / C-13 to C-1 High Energy, Nuclear, Particle Physics 31
How to convert? Computing & Technology 2
How do i convert...? Classical Physics 7
