| Thread Closed |
normal subgroup of prime order in the center |
Share Thread |
| Oct25-07, 01:49 AM | #1 |
Let H be a normal subgroup of prime order p in a finite group G. Suppose that p is the smallest prime dividing |G|. Prove that H is in the center Z(G). 2. Relevant equations the Class Equation? Sylow theorems are in the next section, so presumably this is to be done without them. 3. The attempt at a solution Not completely sure of a solution, but here's (at least some of) what we know: 1. Since H is normal, [tex]ghg^{-1} \in H[/tex]. 2. Since [tex]|H|[/tex] is prime, [tex]H[/tex] is cyclic and abelian. 3. [tex]G[/tex] is finite, with order [tex]|G| = p^nq[/tex]. 4. The normalizer [tex]N(H)[/tex] (stabilizer under conjugation) is all of [tex]G[/tex]... 5. ...so [tex]|G| = |N(H)|[/tex] ?? 6. Probably some more relevant properties. And we want to show that [tex]H \subseteq Z(G)[/tex], i.e. [tex]H \subseteq \{g \in G | gx = xg \forall x \in G\}[/tex] |
| Oct25-07, 02:45 AM | #2 |
So would these things imply that H = G is cyclic, thus abelian and is the center?
| Oct25-07, 12:35 PM | #3 |
Well, from the facts you've given, since H has prime order, it's cyclic, and every cyclic group is abelian. Now since H is normal, like you've also shown we have
[tex]ghg^{-1} \in H[/tex] It can quite easily be shown that this is true if [tex] \forall g \in G[/tex] [tex] \forall h \in H, gh \in Hg[/tex] that is, [tex] \exists h' \in H[/tex] such that [tex] gh = h'g[/tex] but H is abelian so...make some conclusion. Since this holds for every member of H when applied to every member of G, the result follows |
| Oct25-07, 03:40 PM | #4 |
I misinterpreted the problem. i was thinking of G acting on H, as a subgroup, and not of G acting on H element-wise, by just permuting the elements around in H.
this means if H was not in Z(G), then its orbit would have order 2,...,p-1, none of which divide |H| and |G| since p is prime and it's the least prime that divides |G|. i believe this does it. |
| Thread Closed |
Similar discussions for: normal subgroup of prime order in the center
| If K is a subgroup of G of order p^k, show that K is subgroup of H | Calculus & Beyond Homework | 0 | ||
| Inner Automorphisms as a Normal Subgroup | Calculus & Beyond Homework | 3 | ||
| Normal Subgroup | Linear & Abstract Algebra | 4 | ||
| Normal subgroup or not? | Linear & Abstract Algebra | 4 | ||
| normal subgroup thm | Linear & Abstract Algebra | 11 | ||
