Measuring Elasticity of Balls using Collision Method
  • Thread starter Thread starter camperstrike
    Balls Elasticity
The discussion focuses on measuring the elasticity of balls using a collision method, specifically utilizing an air track, blower, gliders, motion sensors, and two tennis balls. Participants emphasize the importance of defining elasticity and identifying measurable quantities for the experiment. The setup requires precise equipment to ensure accurate measurements of the balls' elastic properties during collisions.
  • Understanding of elasticity in physics
  • Familiarity with experimental setup using an air track
  • Knowledge of motion sensors and their application in measuring velocity
  • Basic principles of collision mechanics
  • Research the definition and mathematical formulation of elasticity
  • Learn how to set up and calibrate motion sensors for accurate data collection
  • Explore collision theory and its application in measuring elastic and inelastic collisions
  • Investigate data analysis techniques for interpreting results from collision experiments
Physics students, educators conducting experiments in mechanics, and researchers interested in material properties and collision dynamics.
camperstrike
This is quite tricky..
How to measure the elasticity of balls using a collision method?
apparatus:
air track
blower
gliders
motion sensors (2 sets)
2 tennis balls
How do i do this?
apparatus:
air track
blower
gliders
2 tennis balls
How do i do this?
If you're trying to set up an experiment, you should start by listing the quantities you are trying to find and the ones you are able to measure. What is the definition of elasticity?
