Register to reply
Internal Resistance of a Battery
by robbondo
Tags: battery, internal, resistance
Share this thread:
robbondo
#1
Oct25-07, 11:39 PM
P: 90
The potential difference across the terminals of a battery is 8.20 V when there is a current of 1.54 A in the battery from the negative to the positive terminal. When the current is 3.56 A in the reverse direction, the potential difference becomes 9.40 V. What is the internal resistance r of the battery?
2. Relevant equations
V_ab = E - Ir
3. The attempt at a solution
So I thought that it would make no difference if the charge was reversed. So I just plugged the values into the equations, so since I have two equations and two variables I could solve for r.
8.56 = E - 1.54r -> E = 8.56 + 1.54r
9.40 = E - 3.56r -> E = 9.40 + 3.56r -
0 = -.84 - 2.02r
r = -.416
Obviously the resistance can't be negative. What am I doing wrong, does it have something to do with the reversing part of the problem?
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
dynamicsolo
#2
Oct25-07, 11:51 PM
HW Helper
P: 1,662
Quote Quote by robbondo View Post
In your second equation, remember that the direction of the current is reversed. (Just like in a pre-Star Wars science-fiction movie: "Reverse the polarity!")
robbondo
#3
Oct25-07, 11:54 PM
P: 90
I don't understand why that makes a difference, because won't the change in potential be the same? So what's negative the potential or the amps??? I'm confused.
dynamicsolo
#4
Oct26-07, 12:08 AM
HW Helper
P: 1,662
You are asked to reverse the direction of the current through the battery. In the first part, the current flows from the negative to positive terminal within the battery, so you may write
8.20 V = E (in V) - (1.54 A) r (in ohms) ,
as you did.
But in the second part, we are told that the 3.56 A current is being applied in the opposite direction (positive to negative terminal inside the battery), so the sign of the current must be switched.
robbondo
#5
Oct26-07, 12:16 AM
P: 90
Thanks. I guess I need to go back and read up on charges deff. of a Coulomb and such. I knew the potential would be the same.
dynamicsolo
#6
Oct26-07, 12:20 AM
HW Helper
P: 1,662
You should get a small value for the battery's internal resistance. (It's typically a fraction of an ohm in such problems.)
Register to reply
Related Discussions
Internal resistance of battery Introductory Physics Homework 1
What is the internal resistance of a battery? General Physics 2
Emf + Internal Resistance of Battery Advanced Physics Homework 4
Internal Resistance of a Battery Introductory Physics Homework 14
Internal Resistance in a Battery Introductory Physics Homework 2
