Thread Closed
Evaluating Double Integrals: Switching the Order of Integration
Share Thread Thread Tools
Oct27-07, 03:23 PM   #1
Alw
Evaluate the double integral by changing the order of integration in the iterated integral and evalutating the resulting iterated integral.
2. Relevant equations
[tex]\int[/tex][tex]^{1}_{0}[/tex] [tex]\int[/tex][tex]^{1}_{x}[/tex] cos(x/y)dydx
3. The attempt at a solution
I know how to solve a double integral after i've switched the order of integration, i'm having trouble with the acutal switching part The book we are using has one example in it regarding this, and it isn't very clear. If anyone would mind walking me through how to switch the order of integration, that'd be great
Thanks in advance,
-Andy
edit: The text for the integrals didnt come out well, to make it more clear, its the integral from 0 - to - 1 and the integral
from x - to - 1
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct28-07, 12:58 AM   #2
Recognitions:
Homework Helper Homework Help
Why must you change the order? The integral is easily solvable as it is.
Oct28-07, 02:21 AM   #3
Recognitions:
Gold Membership Gold Member
Quote by Gib Z View Post
Is it? I can't see how.
It always helps if you sketch the area over which you're integrating. Notice that the limits in x are from 0 to 1.
So, the area over which you're integrating is bounded in the x direction by the lines x=0 and x=1. Also, since the limits in y are from x to 1, the boundaries in the y direction are the lines y=x and y=1. Can you sketch the area now? From this, can you figure out how to switch the order of integration?
Oct28-07, 02:27 AM   #4
Recognitions:
Quote by siddharth View Post
I read it wrong :( I seemed to read cos (y/x) >.<" Damn
Oct28-07, 10:12 AM   #5
Alw
Ok, thanks! so if i'm not mistaken then, the new equation is:
[tex]\int[/tex][tex]^{1}_{0}[/tex] [tex]\int[/tex] [tex]^{y}_{0}[/tex] cos(x/y)dxdy ?
Oct28-07, 12:16 PM   #6
Recognitions:
Retired Staff Staff Emeritus
Yes. In your original integral x ranged from 0 to 1 and, for each x, y ranged from x to 1. That is the triangle with vertices (0,0), (1,1) and (0, 1). In the opposite order, to cover that triangle, y must range from 0 to 1 and, for each y, x must rage from 0 to y.
Thread Closed
Thread Tools
Similar Threads for: Evaluating Double Integrals: Switching the Order of Integration
Thread Forum Replies
Evaluating integrals or not? Calculus & Beyond Homework 7
Evaluating Line Integrals Calculus & Beyond Homework 1
Integration/Double Integrals Advice Required General Math 5
Evaluating these integrals.. Introductory Physics Homework 4
Help evaluating these integrals Calculus 1
