Gauge-invariant measure in LQG
  • Context: Graduate
  • Thread starter Thread starter kakarukeys
    Lqg Measure
The discussion revolves around the use of gauge-invariant and diffeomorphism-invariant measures in loop quantum gravity (LQG). Participants explore the implications of these measures for constructing quantum theories, particularly focusing on inner products and the challenges associated with gauge invariance.
  • Some participants inquire about the necessity of gauge-invariant measures in quantum configuration space, suggesting that invariance under gauge transformations is important for the inner product.
  • A participant defines a gauge-invariant measure as one that remains unchanged under the action of a group, providing an example related to the translation group.
  • It is proposed that gauge-invariant measures are essential for creating gauge-invariant theories with corresponding inner products.
  • Questions are raised about the possibility of constructing a gauge-invariant inner product if no gauge-invariant measure is available.
  • One participant expresses uncertainty about LQG but suggests that gauge invariance guides the construction of theories, noting that calculations often require choosing a gauge, which may obscure physical interpretations.
  • Another participant emphasizes that while gauge invariance is crucial for theory construction, it does not preclude the possibility of constructing a Lagrangian without it.
  • A claim is made that finding a gauge-invariant measure in loop quantization is significant, contrasting it with traditional canonical quantization methods that use ill-defined measures.
  • Further inquiry is made regarding the nature of the measure in loop quantization and its relation to gauge manifolds, mentioning concepts like the Fadeev-Popov delta function.
Participants express a range of views on the role and implications of gauge-invariant measures, with no clear consensus on the necessity or implications of these measures in the context of LQG. Some agree on their importance, while others question their physical significance and the feasibility of constructing inner products without them.
Limitations include potential missing assumptions regarding the definitions of gauge invariance and diffeomorphism invariance, as well as unresolved mathematical steps related to the construction of measures and inner products.
kakarukeys
Could someone explain to me why we use a gauge-invariant and diffeomorphism-invariant measure on the quantum configuration space? Is it because we want the inner product to be invariant under gauge transformations. What is a gauge-invariant measure anyway?
see
http://arxiv.org/abs/hep-th/9305045
A measure invariant under the action of the group. For example the measure on the real line R invariant under the translation group is the usual dx:
[tex]\int_R dx f(x) = \int_R dx f(x+a)[/tex]
And we use them to create gauge invariant theories with gauge invariant inner products.
if there is no gauge-invariant measure available, can a gauge-invariant inner product be constructed?
Don;t know much about LQG, but assuming it is constructed along the lines of a normal quantum theory...
gauge invariance tells you how to build your theory. You impose gauge invariance, and that gives you a guide as to how to procede. In order to do a calculation, though, you have to pick a gauge---so you use gauge invariance as a tool to write down a langrangian, or something, then you destroy gauge invariance to do calculations. So in a sense gauge invariance is not physical.
Without the gauge invariance, you could still construct a lagrangian. No problem at all---it is still possible to build a theory and write down a lagrangian. This lagrangian will correspond to something that you would have gotten after you chose a gauge in the previous problem.
The diffeomorphism invariance is just the statement that the answer shouldn't depend on the coordinates you use to describe it. It is another type of gauge invariance, in a sense. You write down a lagrangian, given that you have diffeomorphism invarinace. Then you choose a set of coordinates to do calculations.
In answer to your second question, no. But you CAN construct inner products.
Is it right to say? Being able to find a gauge-invariant measure in loop quantization is a big achievement because if we performed a traditional canonical quantization we would be using the ill-defined measure [tex]dA^i_a[/tex], inner product: [tex]\int\Phi^*[A^i_a]\Psi[A^i_a]dA^i_a[/tex]
They are not gauge-invariant.
([tex]A^i_a\tau_i\otimes dx^a[/tex]: SU(2) connection 1-form)
what is the measure A over? A characterizes some gauge manifold, right, so you pick a Fadeev-Popov delta function or something?
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 61 ·
11K
  • · Replies 26 ·
  • · Replies 37 ·
