Thread Closed
Inductance & Resistance in AC
Share Thread Thread Tools
Oct28-07, 01:51 PM   #1
1. Inductor & Resistor connected in series
A circuit comprising of an Inductor & Resistor connected in series.
The values are:
R1 resistor Value 680Ω
Resistance of the Inductor's Windings: (R of L) 98.2Ω
Supply Voltage: 13.2V
Circuit Current: 8.1mA
Supply Freq: 50Hz
Voltage across the resistor R1 5.5V
Voltage across the inductor 10.4V
Questions:
1. Use Ohm's Law to find the voltage dropped across the resistance of the inductor's windings (R of L)
2. Add this value to the voltage dropped across the resistor R1
3. Draw a scaled phasor diagram of the resistive voltage and the supply voltage, to find the voltage dropped across the pure inductance.
My solution so far:
1. = 8.1mA * 98.2Ω = 0.8V
Voltage dropped across R1 = 8.1mA * 680Ω = 5.5V
2. = 0.8V + 5.5v = 6.3V
3. This is where I get stuck
Can anyone Help!!!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct29-07, 05:49 AM   #2
Recognitions:
Homework Helper Homework Help
Draw a line AB of length 13.2 cm, which represents the supply voltage. From A draw an arc of length 5.5 cm, which represents voltage across R. From B draw an arc of length 10.4 cm, which represent the voltage across L.. Find the point of intersection C. Join AC. Drop a perpendicular from B to AC produced. The length of the perpendicular is the voltage across the pure inductance.
Oct30-07, 04:25 PM   #3
Thanks rl bahat.
That works fine... I couldn't see the wood for the trees!
Once again
Cheers
Tommy
Thread Closed
Thread Tools
Similar Threads for: Inductance & Resistance in AC
Thread Forum Replies
inductance Introductory Physics Homework 1
Oscillator with an inductance with nonzero resistance Electrical Engineering 2
What is the theoretical limit to coil inductance over coil resistance? Electrical Engineering 15
Inductive power transfer + sensing resistance via inductance ? Electrical Engineering 6
Finding Resistance and Inductance of solenoid Introductory Physics Homework 3
