Current in relation to magnetic fields and velocity
The discussion revolves around calculating the current flowing through an aluminum rod sliding down inclined conducting rails in a magnetic field. The problem specifies a vertical magnetic field of 0.047 T, an incline angle of 30.0°, and a rod mass of 0.19 kg. The participant attempts to apply the formula F = ILBsin(θ) but struggles with incorporating the gravitational force correctly. The correct approach involves resolving the gravitational force along the incline to accurately determine the current using the formula I = (mg sin(θ)) / (LB). The participant's initial calculation of I = 49.5212766 A is incorrect due to improper handling of the gravitational component.
  • Understanding of magnetic fields and forces (Lorentz force)
  • Knowledge of inclined plane physics
  • Familiarity with Ohm's Law and current calculation
  • Basic trigonometry for resolving forces
  • Study the Lorentz force law and its applications in magnetic fields
  • Learn how to resolve forces on inclined planes in physics
  • Explore the relationship between current, magnetic fields, and motion
  • Review examples of similar problems involving friction and inclined planes
Physics students, educators, and anyone interested in electromagnetism and mechanics, particularly those dealing with problems involving magnetic fields and inclined planes.
Nuru
Magnetic Field on an incline
This is what looks to be a fairly simple magnetic field problem, but I don't have much experience in relating velocities to electrical currents, so I'm a bit stuck. The problem as described is
The two conducting rails in the drawing are tilted upwards so they make an angle of 30.0° with respect to the ground. The vertical magnetic field has a magnitude of 0.047 T. The 0.19 kg aluminum rod (length = 1.6 m) slides without friction down the rails at a constant velocity. How much current flows through the bar?
So my variables to my knowledge are
I = unknown
m = 0.19 kg
B = 0.047 T
a = 9.8 m/s (gravity)
L = 1.6 m
The formula I know for this sort of thing is simply [tex]F = ILB\sin{\theta}[/tex]. My first approach was to use the relation [tex]F\,=\,MA[/tex] and substitute that in so I had: [tex]MA\,=\,ILB\sin{\theta}[/tex]
This turns into [tex]I\,=\, \frac{MA}{LB\sin{\theta}}[/tex]
So [tex]I\,=\,\frac{(.19 kg)(9.8 m/s)}{(1.6 m)(0.047 T)\sin{30}}[/tex]
then [tex]I\,=\,49.5212766[/tex]
However, that obviously isn't right. Did I miss an important detail? I found another problem which was identical except that it had a frictional coefficient they applied in the numerator and they had a [tex]\theta[/tex] of 90. Unless I misunderstood something it seems like this should be solvable the same way. Any help would be appreciated.
I think the problem is that I'm using the gravity component in the y-axis instead of for the plane, but I'm not sure how to do that correctly.
