Estimating Diffusivity of Freon using known Diffusivity of Methane
  • Thread starter Thread starter lewdtenant
    Methane
The diffusivity of CCl2F2 (freon-12) can be estimated using Graham's law, which relates the rates of diffusion of two gases to their molecular weights. Specifically, the formula Rate1/Rate2 = (M2/M1)^1/2 is applied, where M represents molecular weight. The known diffusivity values of methane in both air and water serve as the basis for this estimation. This method provides a straightforward approach to calculating the diffusivity of freon-12 in various media.
  • Understanding of Graham's law of effusion and diffusion
  • Knowledge of molecular weights of gases
  • Familiarity with diffusivity concepts in fluid dynamics
  • Basic mathematical skills for applying ratios and square roots
  • Research the molecular weight of CCl2F2 (freon-12)
  • Learn about the application of Graham's law in different mediums
  • Explore the effects of temperature and pressure on gas diffusivity
  • Investigate experimental methods for measuring diffusivity in air and water
Chemical engineers, environmental scientists, and researchers involved in gas diffusion studies will benefit from this discussion, particularly those focused on estimating the diffusivity of refrigerants and other compounds.
lewdtenant
How can I estimate the diffusivity of a compound such as CCl2F2 (freon-12) using the known diffusivity of methane?
I would like to estimate it for both air and water. I have a diffusivity value of methane for each medium.
Any advice/help is much appreciated.
Ok so I figured it out, after an extensive google search.
You have to use Graham's law, which states:
M = Molecular Weight
(For anyone that cares)
  • · Replies 20 ·
  • · Replies 30 ·
