| Thread Closed |
diff. equation help |
Share Thread | Thread Tools |
| Oct29-07, 02:48 AM | #1 |
diff. equation help
(3x-2y+1)dx+(3x-2y+3)dy=0 this a piece of my solution: (pls correct if i'm wrong) I thought of solving it using miscellaneous substitution using (3x-2y+1) as u... du= 3dx- 2dy ,dx=(du+2dy)/3 so, >u[(du+2dy)/3) + udy +2dy =0 >u(du +2dy) + 3udy + 6dy =0 >udu +(5u+6)dy=0 >[u/ (5u+6)] du + dy =0 integrating it: > (5u+6)/25 + 6/25 [ln (5u+6)] + y = 0 >(5u+6) + 6[ln(5u+6) + 25y =0 >(15x-10y+11) + 6[ln(15x-10y+11)] +25y =0 but this answer is way too different from the answer on the book the answer there is: 5(x+y+c) = 2ln[15x-10y+11] ... what could be my mistake? 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Oct29-07, 05:32 AM | #2 |
Recognitions:
you ans is same as the book's....simplify it!
note you are basically doing the reverse of this f(x,y)=K where K is some constant then [tex]\frac{\partial f}{\partial x}\frac{dx}{dt} + \frac{\partial f}{\partial y}\frac{dy}{dt} =\frac{df}{dt}=\frac{d(K)}{dt}=0[/tex] where K is 5c in your book I think |
| Oct29-07, 07:26 AM | #3 |
thanks.. but uhm.. sorry I do not understand it well.. could you please explain further how can i simplify so that i could come out to the same answer as the book.. please.
| Oct29-07, 08:03 AM | #4 |
diff. equation help
Okay, you made a mistake in integration:
(u/ (5u+6))du + dy = 0 ((1 - (6/5u+6))/5) du +dy = 0 On integrating: 15x-10y+11 - 6ln(15x-10y+11) +25y = k 15x+15y+11+k = 6ln(15x-10y+11) 15(x+y+c) = 6ln(15x-10y+11) 5(x+y+c) = 2ln(15x-10y+11) Done! |
| Oct29-07, 08:08 AM | #5 |
a.. ok.. wow, never noticed that.. thanks a lot!
| Thread Closed |
| Thread Tools | |
Similar Threads for: diff. equation help
| differential equation - 2nd order diff equation | Calculus & Beyond Homework | 5 | ||
| help with diff. equation | Calculus & Beyond Homework | 3 | ||
| Diff Equation | Differential Equations | 3 | ||
| Diff.equation | Calculus & Beyond Homework | 6 | ||
| Another First Ord. Diff. Equation | Introductory Physics Homework | 7 | ||
