Light through polarizing filters
  • Context: Undergrad
  • Thread starter Thread starter clinchem
    Filters Light
The discussion revolves around the behavior of light as it passes through polarizing filters, particularly focusing on the phenomenon where a third polarizer at a 45-degree angle allows light to pass through two other polarizers that are oriented at 90 degrees to each other. Participants explore the underlying principles and seek to clarify the mechanics of this behavior.
  • One participant expresses confusion about how light can pass through three polarizers when the first two are oriented perpendicularly, suggesting a need for a clearer explanation.
  • Another participant references Malus' law, implying that the mathematical framework should be trusted for understanding the light transmission through polarizers.
  • Some participants provide analogies, such as swinging a rope to illustrate how polarization works, noting that the amplitude of the wave changes depending on the angle of the polarizers.
  • There is a discussion about the amplitude reduction of light as it passes through polarizers, with calculations presented for the factors involved when using a 45-degree polarizer.
  • One participant questions the analogy of the rope, suggesting that the movement of the rope does not perfectly represent the behavior of electromagnetic waves, particularly in terms of reversibility and nonlinearity.
Participants do not reach a consensus on the best explanation for the phenomenon. While some agree on the utility of mathematical explanations, others challenge the adequacy of analogies and express uncertainty about the implications of nonlinearity in the polarizing process.
Some participants highlight the nonlinear nature of polarizers and the irreversibility of light paths, indicating that assumptions about wave behavior may not fully capture the complexities involved.
clinchem
Since a long time I am intrigued by the following experiment: Polarizing filters remove light polarized at 90° to the filter's polarization axis. If a horizontal polarizer is placed on top of a vertical polarizer, there is minimal light transmission. So far "understandable". Now put a third polarizing filter in between the other two filters at an angle of 45 degrees (diagonally) and light gets through! is there anyone that can at least try to make this understandable for me?
thanks in advance
At some point you have to believe the mathematics (of Malus' law in this case)
and not look for a more naive explanation.
or Murphy's Law
thanks in advance
Imagine to swing on a vertical axis a rope held on a wall at one end: you move up and down the other end and you make the rope take the form of a vertically polarized wave. Then put, half distance from your hand and the wall, a big disk with a diametrical slit so that the rope goes through it, and rotate the disk at various angles; the wave can pass perfectly through the slit when this is vertical, it doesn't pass through it when it is horizontal, and it have a reduced amplitude in the other cases; specifically, it will (theoretically) have half amplitude at 45°, and it will be 45° polarized in this case (can you see it? Think about components).
If now you put another disk, further rotated of 45° (so that it is at 90° with respect to the vertical, that is, horizontal), then half of the last wave will pass, so you have now 1/4 of the initial amplitude.
So, a single horizontal disk (at 90°) will block the wave completely, while two disks at 45° the first and 90° the second will transmit 25% of it.
I think Malus is simpler.
So cruel; lightarrow gave an excellent explanation that reminds us why this is purely a classical wave phenomenon.
The incident sinusoidal light wave passes readily through a parallel polarizer. When a second polarizer is oriented perpendicular to the first, the projection of the light wave through the second polarizer has an output amplitude of zero, i.e., cos290o=0
In the case with an intervening 45o offset polarizer, the projection of the incident wave through the intermediate polarizer reduces the initial amplitude by a factor cos245o=1/2. The transition through the third polarizer has a similar projection, where now the initial amplitude is reduced by an overall factor 1/2 x 1/2=1/4.
Thanks! :smile:
Interesting explanation. But the rope can't move vertically before the 45 degree slit and diagonally behind it ! Instead the rope would move a little sideways even before the slit. Does this happen with the EM wave too ? Not sure.
I guess the trouble with the polarizer comes from the easily overseen fact, that it is a nonlinear element (as in the rope case if this explanation is correct). Which one can see from the fact that the light path is not reversible. Send a vertically polarized beam to the 45 degree filter and it comes out at 45 degrees. But sending a 45 degree beam from behind doesn't give you a vertically polarized one.
  • · Replies 20 ·
  • · Replies 43 ·
  • · Replies 17 ·
  • · Replies 17 ·
