Understanding the Refractive Index in QED by Feynman
  • Context: Graduate
  • Thread starter Thread starter jobyts
    Index Refractive index
The discussion revolves around the factors influencing the refractive index of materials as described in Feynman's QED book. Participants explore the relationship between material properties and refractive index, including classical explanations and the effects of external conditions.
  • One participant inquires about the specific properties of materials that lead to different refractive indices and the nature of delays in photon re-emission in various media.
  • Another participant explains that the refractive index is related to how easily materials can form electric or magnetic dipoles, with electric permittivity and magnetic permeability being key factors in determining the speed of field propagation.
  • A different viewpoint notes that external factors like applied electric fields and temperature can influence the refractive index, affecting both its value and its variability under different conditions.
  • Another contribution highlights that in certain materials, the refractive index may not be well-defined due to anisotropic responses to applied fields, requiring the use of matrices to describe permittivity and index. Additionally, it is mentioned that non-linear responses occur at high field amplitudes, complicating the relationship further.
Participants express various perspectives on the factors affecting refractive index, with some agreeing on the role of dipoles and external influences, while others introduce complexities such as anisotropy and non-linearity, indicating that the discussion remains unresolved with multiple competing views.
Limitations include the dependence on specific material definitions and the unresolved nature of how external factors quantitatively affect the refractive index across different materials.
jobyts
(I'm still reading the QED book by Feynman...)
What property of the material causes a specific refractive index for a particular medium? (in other words, from the FAQ section by ZapperZ, "So the lattice does not absorb this photon and it is re-emitted but with a very slight delay.". How is the delay different between different materials.)
Science news on Phys.org
Classically, it comes down to how easily a material can form electric or magnetic dipoles. In a dielectric, for example, when an electric field is applied, the bound electrons will move further away from their host nuclei, forming dipoles which will in turn reinforce that field. For most materials the polarization of the material is proportional to the applied field, and the constant of proportionality is wrapped up into the electric permittivity. Likewise, applied magnetic fields will often induce a proportional response in the magnetic polarization: this is wrapped up into a constant known as the permeability. Together, the permittivity and permeability determine the speed of field propagation through the material, which in turn gives the index.
Note too that the refractive index can be influenced by external factors as well such as applied E-field and temperature. The things Manchot mentions don't just affect the refractive index, but also how the refractive index changes as a function of these external factors.
Claude.
Yeah, and you should also note that the refractive index may not even be well-defined for some situations. For example, in some materials like crystals or polymers, the polarization responds to an applied field anisotropically, meaning that certain directions are preferred over others. In these cases, the permittivity and index must be described by matrices. In other materials, the polarization responds to an applied field non-linearly, in which case the index is a function of field amplitude. As a matter of fact, all materials are essentially nonlinear for large fields: when a field larger than the breakdown field strength is applied, a dielectric becomes conductive, and all of this goes out the window.
20K
