Advantages of Larger Syringe Barrels for Aspiration & Pathology Removal
  • Thread starter Thread starter Syringe User
    Syringe
Using larger diameter syringe barrels for aspiration may offer some advantages, particularly in the initial phase of fluid sampling when air is being replaced by the sample. However, once the catheter is filled with fluid, the aspiration rate becomes largely independent of the syringe diameter due to the constant atmospheric pressure limit. The discussion highlights that while a larger barrel may allow for easier plunger manipulation, the suction force achieved is not significantly enhanced by increasing the barrel size beyond a certain point. The introduction of a three-way valve could facilitate more efficient fluid transfer, but the overall suction force remains consistent across different barrel sizes. Ultimately, the primary benefit of a larger syringe barrel may be in volume capacity rather than increased aspiration efficiency.
Syringe User
We need to figure out the advantage, if any, of using a larger diameter barrel syringe to aspirate fluid and pathology (cells, blood clot & tissue) from a patient using identical size catheters or needles.
Lets ignore that, all things equal, it takes more force to pull back a larger plunger for the momement. The below will be using identical 100cm catheters with 1.5mm inner lumens.
1. What will the aspiration difference be between a syringe barrel with a 29mm and a 40mm diameter if each have an identical 40mm stroke (plunger travel)?
2. Will the larger barrel pull liquids or solids faster through a catheter if connected to a catheter and the plunger is pulled back once?
3. Consider that we can put an automatic three-way valve on the tip of the syringe. The valve will open to suction from a catheter when the plunger is pulled back to aspirate, then the valve will automatically close to the catheter and open to a drain bag to eject the fluid/pathology in the barrel when the plunger is pushed back in. A user can then pulse the plunger open and closed to pull aspiration/drain. Given this 3-way valve, will a 29mm or a 40mm barrel give more suction-aspiration force?
We know of a new syringe design that allows physicians to pull negative pressure easier than before and are tying to hypothesis the benefits of it's use in aspiration biopsy and thrombus removal. For example, if the plunger is all the way pushed in on the 40mm diameter syringe and the tip is sealed, I cannot pull the plunger back with two hands using a traditional syringe design. But, with this new design, a child can pull back the plunger with one-hand on the 40mm diameter design. Knowing that we max out at 1atm of vacuum, what will the advantage be besides more volume. Can we get more aspiration, suction or negative pressure force?
There will be an advantage only on the first aspiration while the air in the catheter lumen is being replaced by sample fluid. That advantage will be minor as air is much easier to draw than a liquid. The rate will be quite independent of the syringe diameter once the lumen is filled with sample fluid. That is because the atmospheric pressure limit is independent of syringe diameter, so the suction force moving fluid along the catheter is constant.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
