Calculating Water Flow Rate in Sloped Reservoir | Simple Calculus Question
  • Thread starter Thread starter Darkiekurdo
    Calculus
The problem involves calculating the rate at which the surface of water is rising in a reservoir with a square cross-section that slopes at a 45-degree angle. The dimensions of the reservoir and the rate of water flow are given, and the original poster seeks to derive an expression for the rising water level based on these parameters.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the shape of the reservoir, identifying it as a truncated pyramid. They explore the volume formula and its application to the problem, questioning how to express volume in terms of height and base dimensions.
The discussion has progressed through various interpretations of the problem, with participants offering guidance on deriving the volume expression and considering the relationship between volume, height, and time. There is an ongoing exploration of differentiation to find the rate of change of height with respect to time.
Some participants express uncertainty about the mathematical concepts involved, indicating varying levels of familiarity with related rate problems. The original poster has not provided specific equations, leading to a reliance on collaborative reasoning to navigate the problem.
Darkiekurdo
A reservoir of square cross-section has sides sloping at an angle of 45 degrees with the vertical. The side of the bottom is p feet in length, and water flows in the reservoir at the rate of c cubic feet per minute. Find an expression for the rate at which the surface of the water is rising at the instant its depth is h feet. Calculate this rate when p = 17, h = 4 and c = 35.
Not stated
I don't know how to begin, I'm sorry. :frown:
Start by trying to find an expression for the volume V as a function of h and p.
What shape is the reservoir?
Did you read the problem? It's a truncated pyramid with square cross section.
Hmm. I didn't know that. How did you come up with that?
I read the first sentence of the problem you posted.
Did you even read the problem? You asked the question and it seems like you haven't even read it. The first sentence describes the shape of the resevoir.
Of course I read it but I didn't know what that was. Sorry.
Anyway, the volume of a truncated pyramid is
[tex]V = \frac{H}{3}(A + a + \sqrt{Aa})[/tex]
right?
Right, if the A and a are the areas of the top and bottom.
What should I do next?
Apply that formula to your problem. If the reservoir is filled to height h, what are the areas of the top and bottom?
So the area of A = p2 and a = (p+2h)2.
Now you are cooking. What's the formula then for the volume V in terms of p and h?
Then I'll just substitute those in the formula for the volume:
[tex]\frac{H}{3}[p^2 + p(p + 2h) + (p + 2h)^2][/tex]
H=h, right? Now to make life easier later, I would expand that out. Now you have V as a function of p and h. What next? Please don't say "I don't know".
Yeah, I should have written it as 1/3h instead of H/3 actually.
Thus,
[tex]p^2h + 2ph^2 + \frac{4}{3}h^3[/tex]
Better and better. What next?
I'm stuck. :(
Maybe we should take time in consideration?
Sure. You must have done some other rate problems, right? Review them.
I'm just beginning with these so I'm not very familiar with those. I'll try though:
*something*time = [tex]p^2h + 2ph^2 + \frac{4}{3}h^3[/tex]
*something* = c. :-p
So:
ct = [tex]p^2h + 2ph^2 + \frac{4}{3}h^3[/tex]
Think derivatives. dV/dt is the rate water is coming in. dh/dt is the rate that it's rising.
So we need to find dh/dt?
That's what they are asking for, right?
Sure. That derivative is
[tex]\frac{c}{(p + 2h)^2}[/tex]
Then it's just substituting the required values.
No. How did you get that? Differentiate your expression for V with respect to t, remember h=h(t) is a function of time.
t = dt/dh. So c*dt/dh = p2 + 4ph + 4h2 = (p + 2h)2. Thus we get
dt/dh = [tex]\frac{c}{(p + 2h)^2}[/tex]
Actually, that's right. Apologies. But it's dh/dt, not dt/dh.
  • · Replies 56 ·
