Optimization in problem solving and studying
The discussion revolves around the concept of optimization in mathematics, particularly its applications in problem-solving and studying for exams. Participants explore the definition of optimization, its purpose, and how it can be applied to various mathematical problems, including maximizing areas and volumes under certain constraints.
  • Homework-related
  • One participant expresses uncertainty about optimization, asking for its definition and applications, particularly in relation to maximizing or minimizing quantities in problems.
  • Another participant notes that there is no single method for solving optimization problems, emphasizing the need to relate unknown quantities to maximize or minimize a given quantity.
  • A specific example involving maximizing the area of a fenced region is discussed, where a participant outlines a process to derive the dimensions that yield the maximum area.
  • Questions are raised about whether the dimensions (x and y) are always the same in optimization problems and whether optimization is solely focused on maximizing volume or if it can also involve minimizing volume.
  • One participant provides a calculation for maximizing the area of a fence, suggesting that a square configuration yields the maximum area of 2500 ft² with each side measuring 50 feet.
Participants express varying levels of understanding and approaches to optimization, with no consensus on a single method or definition. Questions remain about the nature of dimensions in optimization problems and the scope of optimization beyond maximizing volume.
Some participants mention specific constraints and examples, but there are unresolved assumptions regarding the general applicability of optimization techniques and the conditions under which they hold true.
SpicyRamen
This might be a stupid question, I'm not use to asking questions about math...
I just started on optimization. Can someone tell me What optimization is used for and how I could apply it to a problem. When it comes to a problem, I could do it like if it asks " Find two numbers that satisfy the given requirements,' The sum of (S) and the product is maximum.'" Like when They ask me that I can definitely do that no problem, but my teacher usually gets us with blinding questions that I have never seen before in our books, I know he's only trying to prepare us for the Ap exam, but sometimes No matter how much I study from the book I just don't know how to prepare for the test. He teaches us the material and I'm all like "Hey I totally get how to do this" But during the test he gives us problems we have never seen before and wants us to apply what we learn, so I want to prepare for the worst. I want to know why optimization is used. I know it's used to find max volume, minimum distance and area and min length, But why? Can someone give me a definition of optimization or show me using an equation how it originates.
There's no set way to do optimization problems. Really the only things that all the problems have in common is that to solve you need to find a way to relate the unknown quantities that will maximize/minimize another given quantity. It's used just as is says to optimize. If you can relate a unknown quantity(s) in a way which maxs/mins the given quantity.
Say we're maximizing a fence, you've got 200 ft of fence and you're asked to maximize the area. Basically you go through a process find a way to relate the variables (x and y would be used here i guess) to the area. If you maximize the function relating the sides of the fence to the area then you get the dimensions (of the fence in x and y) which would make the area the largest it can ever be with the given constraints.
So for the problem you gave me
I would write-
A= x+y
200= xy
y=200/x
A=x+(200/x)
=1-(200/x^2)
X= (200)^(.5)
= 10*(2)^.5
Y= 10*(2)^.5
Is x and y always the same? And when we're finding the max volume is the base always square(Shape)? Is optimization only used to find the max volume, is there a min volume?
Area=length x width=x*y
Parameter=2x+2y=200
In the case of a fence you'd maximize the are if you made a square fence so you can fairly easily see that the maximum area is 2500 ft^2 with each side being 50 feet.
  • · Replies 18 ·
  • · Replies 24 ·
