Voltage Regulator: Need 2 Amps? What Can I Do?
The discussion revolves around the use of a +5V Fixed-Voltage Regulator 7805 in a project requiring 2 amps of current. Participants explore alternatives, the performance of the 7805, and the implications of heat on its operation, including the necessity of additional components like capacitors and heatsinks.
  • Homework-related
  • One participant notes the 7805 can only supply a maximum of 1 amp, prompting the search for alternatives.
  • Several participants suggest looking for higher current regulators, such as a 3 amp 5V regulator, and provide links to datasheets and resources.
  • Questions arise about the necessity of heatsinks and how heat affects the performance of the 7805, with some participants asserting that higher temperatures can reduce output current.
  • There is a discussion about the importance of capacitors in the circuit, with one participant emphasizing their role in stability and potential oscillation issues if omitted.
  • Clarifications are made regarding the relationship between input and output current in linear regulators, with explanations about how the load determines the current drawn.
  • Some participants express confusion about the input current and voltage relationship, leading to further explanations about how regulators operate.
Participants generally agree on the importance of understanding datasheets and the role of capacitors in regulator circuits. However, there is no consensus on the necessity of heatsinks or the exact impact of heat on the 7805's performance, as well as varying interpretations of how input and output currents interact.
Participants mention the importance of thermal management and the potential for oscillation in linear regulators, indicating that the discussion is nuanced and dependent on specific circuit conditions and configurations.
Individuals working on electronics projects involving voltage regulation, particularly those needing to manage current and heat in linear regulators, may find this discussion beneficial.
jh24628
I was going to use a +5V Fixed-Voltage Regulator 7805, for a project until I noticed that I need 2 amps and the 7805 can supply at max 1 amp. what can I do?
There are a number of different things you could do.
A quick google search on '3 amp 5v regulator' shows
http://www.national.com/mpf/LM/LM323.html
go to digikey and seach linear regulator. put in a filter for 5v and 3amp
after doing some more research I found out I need about 900mA to 1 amp. will the 7805 guarantee putting out that much? and should I put a heatsink on it to help (and how)?
I agree, datasheets are our friends. Also, google can be useful if you know a couple keywords... I just googled heatsink tutorial, and got lots of good hits. This is one of the first ones on the hit list:
http://sound.westhost.com/heatsinks.htm
It describes the concepts of thermal resistance and heatsink sizing, plus gives some useful tips for how to use heatsinks.
ranger said:
The datasheet for the respective regulators will tell you all that info.
http://www.google.com/search?hl=en&q=7805+datasheet&btnG=Google+Search
Learning how to read datasheets is a good thing.
yes I know, but you did not read my question. my question was how does heat impact its performance, I know the hotter the chip is the lower the current output will be. do I need to worry about a heatsink on it at all? according to this at 25 degrees Celsius, it will output 1 amp ( http://www.national.com/mpf/LM/LM78M05.html )
thanks
The current of a voltage regulator does not go down with higher chip temperature, at least not until any internal thermal current limiting circuit kicks in.
Check out the heatsink link I provided -- that should help you figure out your answer.
EDIT -- we're posting simultaneously! LOL.
I hate datasheets...
I have a couple more questions. is it absolutely necessary to have the two capacitors in the circuit
"*Required if regulator input is more than 4 inches from input filter capacitor
(or if no input filter capacitor is used). <- ON INPUT
**Optional for improved transient response." <-ON OUTPUT
and is there a recommended input current? I know the higher the current the more heat made.
input current depends on how much you draw.
heat depends on Vin and current draw. if your 5V regulator can take Vin up to 24V, applying Vin of 24V would generate more heat dissipation than applying Vin of 12V keeping all else constant. Remaining unused voltage gets dissipated as heat i believe.
I guess for the current question i should have rephrased it. I need the regulator to output one amp, would I be safe putting more than one amp to the input of the regulator?
if your regulator can output more than 1 amp, then yes. it will draw what it needs
lets say your regulator can output upto 2A, and you require 1.5A,then yes it will draw only that much
if it can output upto 500mA, and you require 1.5A, your regulator will still output 500mA and cap at that much. You cannot put in 1.5A into the regulator because it can only take in 500mA.
A linear regulator like you are asking about has current going through it from input to output, and it drops a controlled voltage to maintain the output voltage in regulation, even if the input voltage varies. You do not put current into a linear regulator. You supply it with an input voltge, the regulator drops whatever voltage is necessary to make the regulated output voltage, and the output current is determined by that output voltage and the load impedance. The input and output currents for the voltage regulator are equal. (Well, except for the small bias current Iq which flows down through the regulator circuit to ground, which means that Iin = Iout + Iq.)
(maybe this is why I'm not an EE major) but if you are supplying the 7805 with power from a DC power supply, how can the 7805 only have voltage as an input when the dc power supply has both a voltage and current output?
Yes, you are getting a bit confused about the details and the semantics. I'll try again, the output voltage across the load impedance determines the output current of the regulator. This output current is basically identical to the input current, since a linear regulator is basically a pass element. So the input current that the regulator draws from the source power supply is determined by the load impedance, not by any characteristic of the voltage regulator. The input current equals the output current (the current all just flows through the linear regulator), and the input voltage is determined by the voltage setting on the source power supply.
... The input current equals the output current (the current all just flows through the linear regulator), and the input voltage is determined by the voltage setting on the source power supply.
that clears everything up. thanks
Yes.
They keep the regulator stable.
If you leave them out, it may well oscillate.
Series regulators are very good at oscillating.
Usually at about 40 to 50MHz.
Which tends to make whatever circuitry you are supplying do very interesting and unusual things.
It may help you to understand that your load draws the current and that determines how much current your regulator "passes" and not the regulator or power supply themselves necessarily; their current spec is a max rating rather than a given constant so it means they can go up to 1A for example, but they will only ever supply as much current as the load is drawing which could be anything less than 1A. The regulator just varies how much current it takes from the input voltage, your power supply for example, and passes to the output voltage so that no matter the variation of current your load takes, the voltage will remain at a constant regulated level (just remember ohm's law and power equation to see the relationships your regulator is trying to control). Your heat will be generated by how much internal resistance is present in the switching or passive components of your regulator. The bigger drop in voltage across the regulator (a bigger difference between input voltage and output voltage), the more power you will dissipate with the regulator for a given current (because current is determined by the load) by the equation of Power = I*V.
If you regulator MAX output current is 1A, your load should be equal or less than 1A. Otherwise, the regulator will be burnt.
Base on you choice of using 7805, there are several ways to design a regulator higher than the max current using "your" 7805 IC.
1. Pick uA7805 type that provides 3A (there have 1A and 3A), or
2. Since your design is not too high power (5V * 3A = 15W), you can find other regulator from linear technology or analog devices
3. Use a shunt circuit with the 7805 to increase the output current.
And above all, don't forget the heatsink!
And the capacitors.
P = (Vin - Vout)*Iout (15W is the max these regulators can handle with a heatsink)
where are you getting 3 amps from? I never mention that.
  • · Replies 32 ·
  • · Replies 49 ·
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 63 ·
