Calculating Minimum Thickness for Aluminum Alloy Tube Supporting Steel Rod
The discussion focuses on calculating the minimum thickness required for an aluminum alloy tube (E=73 GPa) with an outer diameter of 75 mm to support a steel rod (E=210 GPa) under a load of 35 kN, while limiting the maximum deflection to 0.40 mm. Key considerations include the deformation compatibility equation, the calculation of Young's Modulus for the steel rod, and the distribution of forces on the aluminum tube. The total displacement of the steel rod must account for both its elongation under tension and the compression of the aluminum tube.
  • Understanding of Young's Modulus and its application in material science
  • Knowledge of deformation compatibility equations in structural analysis
  • Familiarity with stress/strain relationships in materials
  • Basic principles of load distribution in composite structures
  • Research deformation compatibility equations for composite materials
  • Study the calculation of Young's Modulus in different loading conditions
  • Learn about stress/strain relationships specific to aluminum alloys and steel
  • Explore load distribution methods in structural engineering
This discussion is beneficial for structural engineers, materials scientists, and students studying mechanics of materials, particularly those involved in designing composite structures and analyzing load-bearing components.
mit_hacker
(Q) An aluminum alloy (E=73GPa) tube A with an outer diameter of 75mm is used to support a 25-m-diameter steel (E=210GPa) rod B, as shown (in the attachement). Determine the minimum thickness t required for the tube if the maximum deflection of the loaded end must be limited to 0.40 mm.
I understand if the length of the working puts you off. In that case, can someone please tell me:
(a) What deformation compatibility equation to use?
(b) How is it that for the steel, the load is 35 kN and the length, area and extension are all given? What I mean is that if we calculate the Young's Modulus using those figures, it does not come out to be 200 GPa. In that case, what force do we use?
(c)What is the force on each of the aluminum alloy bars?
The total displacement of the loaded end of the steel bar is to be limited to 0.4 mm.
Excluding the deflection of the horizontal bar, there are two dimensional changes to consider: 1) the steel bar will stretch under tension, which will include the 35 kN load and its own weight, and 2) the contraction of the Al tube(s) under compression. One has to determined the length increase in the steel rod and subtract that from the 0.4 mm, and that result will be used to determine the minimum thickness of the Al tube using the appropriate stress/strain relationship.
This appears to be a homework problem, thus it should be posted in the Homework forums.
10K
  • · Replies 35 ·
9K
