Change in entropy, Gibbs and Helmholtz in an isothermal compression
The discussion focuses on calculating the change in entropy, Helmholtz free energy, and Gibbs free energy for an ideal gas compressed isothermally from 1 atm to 100 atm at 20°C. The participants confirm that the entropy change is given by ΔS = R ln(P1/P2), where R is the gas constant. They also establish that the changes in Helmholtz and Gibbs free energies are equal, expressed as ΔF = ΔG = RT ln(P2/P1). The calculations utilize the ideal gas law and principles from thermodynamics, confirming the relationships between these thermodynamic quantities during isothermal processes.
  • Understanding of the ideal gas law (PV = nRT)
  • Familiarity with thermodynamic principles, particularly the first and second laws
  • Knowledge of entropy and free energy concepts
  • Proficiency in calculus for differentiation and integration of thermodynamic equations
  • Study the derivation of the ideal gas law and its applications in thermodynamics
  • Learn about isothermal processes and their implications in thermodynamic systems
  • Explore the relationships between different thermodynamic potentials, including Helmholtz and Gibbs free energies
  • Investigate the implications of entropy changes in various thermodynamic processes
Students and professionals in thermodynamics, chemical engineering, and physical chemistry who are looking to deepen their understanding of energy transformations and state functions in ideal gases.
T-7
Determine the change in the entropy, Helmholtz free energy, and Gibbs free energy, when a mole of ideal gas is compressed from 1atm to 100atm at 20C.
I am not entirely convinced by my attempt below -- can anyone spot something wrong? (I thought it odd that the entropy change should be temperature-independent...)
From the first law
[tex]dU = dQ - dW = dQ - PdV[/tex]
From the second law,
[tex]dS = dQ / T \Rightarrow dQ = TdS[/tex]
Thus:
[tex]dU = TdS - PdV[/tex]
Transposing to get dS:
[tex]dS = \frac{dU}{T} + \frac{P}{T}dV[/tex]
But the compression takes place at 20C => isothermal => dT = 0 => dU = 0. Thus:
[tex]dS = \frac{P}{T}dV[/tex]
From the ideal gas law,
[tex]PV = RT \Rightarrow V = \frac{RT}{P} \Rightarrow dV = -\frac{RT}{P^{2}}dP[/tex]
Thus:
[tex]dS = -R\frac{dP}{P} \Rightarrow \Delta S = Rln(P_{1}/P_{2})[/tex]
For the Helmholtz free energy, I reason:
[tex]dF = -SdT - PdV[/tex]
isothermal => dT = 0. Thus:
[tex]dF = -PdV[/tex]
Again, using the ideal gas law, rewrite as:
[tex]dF = RT\frac{dP}{P} \Rightarrow \Delta S = RTln(P_{2}/P_{1})[/tex]
And finally, for the Gibbs Free energy, I reason:
[tex]dG = -SdT + VdP = VdP = \frac{RT}{P}dP[/tex]
So, in this case, [tex]\Delta G = \Delta F[/tex]
Is this the right approach?
Cheers!
I took a slightly different approach which otherwise parallels yours and got the same result. If we start from
[tex]PV = RT[/tex] , with T constant, and differentiate, we have
[tex]P dV + V dP = 0 \Rightarrow P dV = - V dP[/tex].
For an isothermal process,
[tex]dU = dQ - PdV = 0 \Rightarrow dQ = P dV = -V dP[/tex] ,
so we can write
[tex]dS = dQ / T = -(V dP/T) = -(RT/PT) dP = - R (dP/P)[/tex] ,
using the ideal gas law. This yields the result you found,
[tex]\Delta S = R ln(P_{1}/P_{2})[/tex] .
If we start from the definitions for the free energies,
[tex]F = U - TS[/tex] and [tex]G = U + PV - TS[/tex] and differentiate, we have
[tex]dF = dU - T dS - S dT[/tex] and
[tex]dG = dU + P dV + V dP - T dS - S dT[/tex].
If we strip away all the terms equal to zero for an isothermal process (dU = 0 , dT = 0), these reduce to
[tex]dF = - T dS[/tex] and [tex]dG = P dV + V dP - T dS[/tex] ;
but, as we showed above, [tex]P dV + V dP = 0[/tex] , so
[tex]dF = - T dS = dG[/tex] .
Thus, applying our result for [tex]\Delta S[/tex],
[tex]\Delta F = \Delta G = RT ln(P_{2}/P_{1})[/tex].
[Almost missed that: the signs flip again going from dS to dF or dG, so the order of the integration limits doesn't reverse this time...]
I suppose that, given the definitions of what F and G are (see Wiki, for instance), it perhaps isn't surprising that [tex]\Delta F[/tex] and [tex]\Delta G[/tex] are the same for this process.
Thanks very much for the confirmation :smile:
9K
