How Do You Graph a Reflection of a Function on the Same Set of Axes?
  • Thread starter Thread starter HelloMotto
    Functions
The discussion centers on graphing the function f(x) = √(x - 4) and its reflections -f(x) and f(-x). The correct equations derived are -f(x) = -√(x) + 4 and f(-x) = √(-x + 4). The participant highlights the challenge of graphing f(-x) due to domain restrictions, specifically that it requires x ≤ 4 for valid inputs. The reflections indicate that -f(x) represents a reflection across the x-axis, while f(-x) represents a reflection across the y-axis.
  • Understanding of function transformations, specifically reflections.
  • Knowledge of domain restrictions for square root functions.
  • Ability to graph functions on Cartesian coordinates.
  • Familiarity with the properties of even and odd functions.
  • Learn about domain restrictions in square root functions.
  • Study function transformations, focusing on reflections and their graphical implications.
  • Explore graphing techniques for piecewise functions.
  • Investigate the properties of even and odd functions in relation to symmetry.
Students studying algebra, particularly those learning about function transformations and graphing techniques, as well as educators seeking to clarify these concepts for their students.
HelloMotto
Given f(x)= square root of x - 4, write the equation for -f(x) and f(-x).
Sketch the three graphs on the same set of axes
Determine any points that are invariant for each reflection
well basically I did the first part of the question and the result i got was
-f(x) = -square root of X + 4
f(-x) = square root of -x -4
the second part where it asks to graph these 3 equations, I've graphed the f(x) equation and the -f(x) equation but I can't graph the f(-x) equation. Simply because i get an error when i try to square root a negative number. So how would i graph this kind of eqation?
...-f(x) is a reflection in the x-axis
and f(-x) is a reflection in the y-axis
Do mean f(x)= sqrt(x+ 4) or f(x)= sqrt(x)+ 4?
If the first, the domain of f is [itex]x+4\ge 0[/itex] or [itex]x \ge -4[/itex] and f(-x) = sqrt(-x+ 4) has domain [itex]-x+4\ge 0[/itex] or [itex]x\le 4[/itex]
If the second, the domain of f is [itex]x\ge 0[/itex] and f(-x)= sqrt(-x)+ 4 has domain [itex]x\le 0[/itex].
You have to take values of x in the correct domain in order to graph f(-x). In any case, rock.freak667 is correct: the graph of f(-x) is the refection of the graph of f(x) in the y-axis.
9K
  • · Replies 23 ·
