Will the Ball Hit the Fence or Pass Above It?
  • Thread starter Thread starter logglypop
    Ball Kinematic
The discussion revolves around a physics problem involving projectile motion, specifically analyzing the trajectory of a ball kicked towards a fence. Participants are tasked with determining whether the ball will hit the fence or pass above it, given specific parameters such as initial velocity, angle of projection, and distance to the fence.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore calculations related to the time of flight and vertical displacement of the ball. There are attempts to clarify the use of horizontal and vertical components of the initial velocity in determining the ball's height at the point it reaches the fence.
The discussion is active, with participants questioning the initial calculations and suggesting the need to consider both the horizontal and vertical components of the ball's velocity. Some guidance has been offered regarding the correct approach to find the height of the ball at the fence.
There appears to be some confusion regarding the application of trigonometric functions to resolve the initial velocity into its components, which is critical for accurately determining the ball's trajectory. The problem also assumes negligible air resistance and provides specific constraints on the initial conditions.
logglypop
A ball of mass 0.5 kg, initially at rest, is kicked directly towards a fence from a point 32 meters away. The velocity of the ball as it leaves the kicker's foot is 20 meters per second at an angle of 37 degrees above the horizontal. The top of the fence is 2.5 meteres high. The kicker's foot is in contact with the ball for 0.05 second. The ball hits nothing while in flight and air resistance is negligible.
Will the ball hit the fence? If so, how far below the top of the fence will it hit? If not, how far above the top of the fence will it pass?
time = distance/velocity
time = 32 m / horizontal velocity
time = 32 m / ((cos 37) * 20) m/s
time = 32 m / ((4/5) * 20) m/s
time = 2 seconds
d = vt + .5at^2
d= 20*2 + .5 (-9.8) 2^2
d=20.4
20.4 - 2.5 = 17.9
the ball won't hit the fence. 17.9m above the fence
need confirm please
You didn't take the angle into account here.
the i guess the
V=20cos37
V=16
d= 16*2 + .5 (-9.8) 2^2
d=13.5m
so the ball 13.5 above the fence?
No, 20cos37 is the x component of the initial velocity. You need to find the y component since you are trying to find out the height of the ball when it reaches the fence.
thanksV=20sin37
V=12
d= 12*2 + .5 (-9.8) 2^2
d=4.4m
Yes, that's the height of the ball above the ground when it reaches the fence.
9K
