Sliding block- thermal energy - please
The problem involves a block of lead being pushed across the floor with a constant horizontal force, examining the thermal energy changes associated with the block and the floor due to friction. The context includes concepts from thermodynamics and mechanics, particularly focusing on energy transfer and work done against friction.
  • Participants discuss the calculation of thermal energy change using the formula Etherm = mCΔT and question the work done by friction, considering the direction of forces relative to motion.
  • Some participants express uncertainty about the relationship between the work done by the applied force and the frictional force, and how these relate to the thermal energy changes in both the block and the floor.
  • There is a discussion about whether the normal force does any work and how to interpret the work done by the block on the floor.
The discussion is ongoing with various interpretations being explored. Some participants have provided insights into the relationships between forces and energy changes, while others are still questioning their understanding of the concepts involved. There is no explicit consensus yet, but productive dialogue is occurring around the calculations and assumptions.
Participants are encouraged to clarify their choice of system in their calculations. There is also a focus on understanding the implications of forces acting in different directions and how that affects work done and energy transfer.
mshah3
You push a block of lead across the floor, applying a horizontal force of 9 N. The block moves at a constant speed. The mass of the block is 1.5 kg and the heat capacity of lead is 130 J/(kg K). After pushing the block a distance of 20 m, you measure its temperature and find that it has increased by 0.3 K.
In answering the following problems, state explicitly your choice of system!
(a) What is the change in thermal energy of the block?
(b) How much work is done by the frictional force of the floor acting on the block?
(c) What is the change in the thermal energy of the floor?
Etherm = mC deltaT
Etherm = Force * delta r = W
PART A : i was thinkin mCdeltaT
Part B: either -Fd or could be zero since the force is perpendicular to motion
Part C: work minus etherm maybe
****need help asap*****THANKS
Etherm = mC deltaT
yes
explain why you think the force is perpendicular (or parallel?) to the motion
explain your logic here.
****need help asap*****THANKS[/QUOTE]
well the block is moving to the right
and the work by floor is moving upward
making it perpendicular to motion
(honestly, part b and c are the ones I am very unsure about)
thank you
thank you
Oh, OK, there are two forces exerted by the floor on the block; the upward normal force of the floor on the block, and the friction (leftward) force of the floor on the block (acting parallel to the floor). The motion of the block is to the right. Using the definition of work, frcostheta, note that the normal force does no work,(since costheta =0), and only the friction force does work. How much work does it do?
-Fd ?
The total change in energy is mc*deltaT.
So the work done by friction + the work done by the 9N force = mc*deltaT
oh ok that makes sense
so Wfric = mct - mgh
then would the etherm for floor be zero?
not mgh... the displacement is not vertical... what is the work done by the 9N force... what is the definition of work?
well i meant change in distance
work = mgdetlar
or wait no ... Fd
mshah3 said:
or wait no ... Fd
yes, exactly.
so:
Wfric = mct - Fd
alright, so how would i get to the etherm of the floor?
What did you get as the work done by friction?
Note that friction is the work done by the floor on the block.
The only object doing any work on the floor is the block...
if x is the work done by the floor on the block... what is the work done by the block on the floor?
negative x
mshah3 said:
negative x
exactly. what numbers do you get?
  • · Replies 20 ·
