2 balls dropped from a building
  • Thread starter Thread starter ronny45
    Balls Building
The problem involves two balls: one thrown upwards from a 21.0m high building and another dropped 1.00s later. To determine the initial speed of the first ball so that both hit the ground simultaneously, the equations of motion are applied. The second ball, dropped with an initial velocity of 0 and under the acceleration of gravity (9.81 m/s²), takes 2.069 seconds to reach the ground. Consequently, the first ball must be in the air for 3.069 seconds, requiring the use of the kinematic equation x = x₀ + v₀t + (1/2)at² to find the necessary initial speed.
  • Understanding of kinematic equations in physics
  • Knowledge of gravitational acceleration (9.81 m/s²)
  • Ability to solve quadratic equations
  • Familiarity with concepts of initial velocity and time of flight
  • Study the derivation and application of kinematic equations
  • Learn about projectile motion and its equations
  • Explore problems involving multiple objects in free fall
  • Practice solving physics problems involving initial velocity and time
Students studying physics, particularly those focusing on kinematics and motion, as well as educators looking for practical examples to illustrate these concepts.
ronny45
A ball is thrown straight up from the edge of the roof of a building. A second ball is dropped from the roof a time of 1.00s later. You may ignore air resistance.
If the height of the building is 21.0m, what must the initial speed be of the first ball if both are to hit the ground at the same time?
v=u+at
v^2=u^2+2as
2s=ut+1/2 at^2
For the second ball,
u=0
a=9.81m/s^2
s=21m
v=?
...v comes out to be 20.298m. Then i found t to be 2.069s. Assuming the first ball was in the air 1 second longer, its time is 3.069.
However, I' not sure how to proceed with the equations for the first ball, since I don't know the maximum height reached by it, though v is 0 at this point.
since you know the time, acceleration, initial and final positions, you should be able to use x = x_0 + v_0 t + (1/2) a t^2 to find the answer.
  • · Replies 38 ·
  • · Replies 31 ·
