Is it ok to do this with the ratio test for series?/
The forum discussion centers on the application of the Ratio Test to the series defined by the general term \(\frac{n (-3)^{n}}{2^{n-1}}\). The initial user mistakenly applied the Root Test, yielding a limit of \(3/2\). However, the consensus confirms that the Ratio Test is the appropriate method for this series, resulting in the same limit of \(3/2\), indicating that the series diverges.
  • Understanding of series convergence tests, specifically the Ratio Test and Root Test.
  • Familiarity with limits and their evaluation in calculus.
  • Knowledge of manipulating algebraic expressions involving limits.
  • Basic understanding of sequences and series in mathematical analysis.
  • Study the application of the Ratio Test in detail, including edge cases.
  • Learn about the Root Test and its limitations in series convergence.
  • Explore examples of series that converge and diverge using various tests.
  • Investigate the implications of series divergence in mathematical analysis.
Students of calculus, mathematicians, and educators seeking to deepen their understanding of series convergence tests and their applications in mathematical analysis.
frasifrasi
Is it ok to do this with the ratio test for series??/
I had the series from 1 to infinity of:
n(-3)^(n)/(2^(n-1))
by applying the root test, i got:
lim as n-->infinity [ 3(n+1)/2n] , so put the 3/2 outside and let the (n+1)/n be n/n --> which means the limit would yield 3/2...
does anyone know if this is how I am supposed to do this?
n(-3)^(n)/(2^(n-1))
I'm reading the general term to be
[tex]\frac{n (-3)^{n}}{2^{n-1}}[/tex].
This is not suitable for the Root Test because of that dang factor of n in the numerator. So I'm presuming you meant the Ratio Test. And yes, I get the same ratio you did. The limit is 3/2, so this series doesn't converge.
