| Thread Closed |
Convergence/Divergence |
Share Thread | Thread Tools |
| Nov5-07, 03:10 PM | #1 |
Determine if the following converges or diverges as x approaches infinity by either evalutation, the direct comparison test, or the limit comparison test: (It's a Calculus II, AP Calculus BC level of problem)
the integral of (lnx/(square root of (x^2-1))), from 1 to infinity. * I do not know how to evaluate the integral analytically, so I tried to use either the direct comparison test or limit comparison test. I can't seem to find another function that will "sandwich" that function (and thus prove convergency) or one that will prove it's divergency. I've tried 1/x, 1/(x^2), etc and I'm stuck. Any help on a function to use would be very much appreciated- I'm frustrated beyond belief! Direct Comparison Test: 0< f(x)< g(x) proves that f(x) converges if g(x) also converges f(x)> g(x)---proves that f(x) diverges if g(x) diverges Limit Comparison Test: if the limit as x approaches infinity of f(x)/g(x) is a finite, non-zero number, then f(x) has the same behavior of convergence as g(x) |
| Nov5-07, 04:06 PM | #2 |
Recognitions:
0 < Ln x < x-1 for all x > 1. Does this help?
| Nov5-07, 04:12 PM | #3 |
look at ln(x)/Sqrt(x^2-1) its only improper at infinity so if you look at what the function looks like when x --> infinity we get ln(x) /x . From this we can compare it to anything that diverges and is smaller than that...easiest example 1/x. ln(x)/Sqrt(x^2-1) > 1/x for all x > 1
| Nov5-07, 04:20 PM | #4 |
thank you, but don't you have to choose a function that is greater/less than for all numbers from 1 to infinity? I don't understand how you can say for x>1, because one itself is the lower limit of the integral and shouldn't it thus be included? or in this type of problem is it to be assumed that the f(x)> g(x) for x>1, not including one?
| Nov5-07, 05:25 PM | #5 |
Recognitions:
That's an easy fix; 0 < Ln x < Sqrt(x-1) for all x > 1. [See edit.]
[Although: "Integral of 1/Sqrt[1+x] does not converge on {1,\[Infinity]}" may be a problem.] I do not think either of these examples is a solution. |
| Nov5-07, 09:07 PM | #6 |
thank you all very much for your help
, but does anyone know what a solution could be? what you're all suggesting makes sense, but nothing works 100%....
| Nov5-07, 11:13 PM | #7 |
Recognitions:
On a 2nd thought, 1/x works, but is a little involved.
a. For 1 < x < 2.5, 0 < ln(x)/Sqrt(x^2-1) < 1/x. b. For x > 2.5, ln(x)/Sqrt(x^2-1) > 1/x. Fact "a" is inconvenient because it seemingly precludes a direct comparison with 1/x (our hope for a divergence result). So here is the involved part. Below, I will use the expressions "F diverges" and "F = [itex]\infty[/itex]" interchangeably. [tex]\int_1^\infty f(x) dx = \int_1^{2.5} f(x) dx + \int_{2.5}^\infty f(x) dx.[/tex] In shorthand, I(1/x) = I1(1/x) + I2(1/x) for f(x) = 1/x. 1/x evaluates to a finite (positive) result over [1, 2.5]. Therefore I1(1/x) is finite (and positive). Let I1(1/x) = J > 0. Then, I(1/x) = J + I2(1/x). Since I(1/x) diverges, so does I2(1/x): [itex]\infty[/itex] = J + I2(1/x) implies I2(1/x) = [itex]\infty[/itex] - J = [itex]\infty[/itex]. Call this Result 1. From fact "b," I2(ln(x)/Sqrt(x^2-1)) > I2(1/x) = [itex]\infty[/itex] (from Result 1). Therefore I2(ln(x)/Sqrt(x^2-1)) diverges. Call this Result 2. Now... We know we can write I(ln(x)/Sqrt(x^2-1)) = I1(ln(x)/Sqrt(x^2-1)) + I2(ln(x)/Sqrt(x^2-1)). Also, I1(ln(x)/Sqrt(x^2-1)) = K > 0 (positive & finite). Can you take it from here? |
| Nov5-07, 11:19 PM | #8 |
Recognitions:
| Nov6-07, 05:04 AM | #9 |
thanks again for all your help, i think i understand it now.
i wasn't asking for a "100%" answer, i was asking for a hint to a solution that worked 100% for this problem, there is a difference. i'll watch my wording next time. |
| Nov6-07, 12:40 PM | #10 |
Recognitions:
Good, nice; am glad to help.
| Nov6-07, 01:25 PM | #11 |
there are numerous number of solution to these kind of problems. you asked to show whether it diverges or converges...it diverges if it is larger than something than diverges then it too diverges (remember the converse is not true) 1/(100x) could be an answer that can work all the times but so can 1/(1004x)
| Nov6-07, 02:47 PM | #12 |
Recognitions:
Midy1420 is right; that's a much simpler solution.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Convergence/Divergence
| Convergence Divergence Help | Calculus & Beyond Homework | 2 | ||
| Convergence and Divergence | Calculus | 4 | ||
| Convergence or divergence | Calculus & Beyond Homework | 3 | ||
| Help with convergence/divergence | Calculus & Beyond Homework | 22 | ||
| PLEASE HELP!!!...Convergence and Divergence!!! | Calculus & Beyond Homework | 1 | ||
