What is the solution for the quantum homework questions?
  • Thread starter Thread starter noospace
    Quantum
The discussion centers on solving quantum mechanics homework questions involving Stern-Gerlach experiments and angular momentum states. For the first question, the user calculated the percentages of electrons measured in the +/- x-directions as 45% and 5%, which does not sum to 100%, indicating a misunderstanding of the measurement process. The second question involves expressing the total angular momentum ket for deuterium, which the user approached correctly by considering the absence of orbital contributions due to the state being l = 0. Clarifications were provided regarding the nature of electron states in the Stern-Gerlach experiment.
  • Understanding of quantum mechanics principles, specifically Stern-Gerlach experiments.
  • Familiarity with angular momentum in quantum systems, including kets and composite states.
  • Knowledge of eigenstates and superposition in quantum mechanics.
  • Basic grasp of quantum state notation and operators, particularly lowering operators.
  • Study the implications of measurement in quantum mechanics, focusing on the Stern-Gerlach experiment.
  • Learn about angular momentum coupling in quantum systems, particularly for composite particles.
  • Explore the mathematical formulation of quantum states and their transformations using operators.
  • Investigate the behavior of charged particles in magnetic fields and the limitations of the Stern-Gerlach setup.
Students and educators in quantum mechanics, particularly those tackling advanced topics in angular momentum and measurement theory. This discussion is beneficial for anyone seeking to deepen their understanding of quantum state behavior in experimental contexts.
noospace
1. Consider a beam of z-oriented electrons, 80 % up, 20 % down which is passed through an x-oriented Stern-Gerlach machine. What percentage of electrons are measured in the +/- x-directions?
2. Consider deuterium. Nuclear spin = 1 with 1 electron orbiting in the n =1 state. Write down the ket for the total angular momentum [itex]|\frac{3}{2} \frac{1}{2}\rangle[/itex] as a linear combination of composite states.
1. I write the eigenstates of [itex]S_z[/itex] in a superposition [itex]\sqrt{0.8} (1,0)^T + \sqrt{0.2} (1,0)^T[/itex] (where T denotes transpose) and set it equal to an linear combination of the [itex]S_x[/itex] eigenstates [itex]a(1,1)^T + b(1,-1)^T[/itex]. Solving for a and b I get 45 % and 5 %. Interestingly they don't add to 100 % which was what I was expecting. Is this physically reasonable?
2. Do I just write [itex]|3/2,3/2\rangle = |1,1\rangle |1/2,1/2 \rangle[/itex] and apply lowering operators? I can do this because l = 0 so there is no orbital contribution to the angular momentum right?
"Consider a beam of z-oriented electrons, 80 % up, 20 % down"
This does not mean the WF you wrote. Each electron would be either pure up or pure down, and 1/2 would go each way in the z direction, just as for an umpolarized beam.
A problem here is that the usual SG experiment does not work for charged particles.
You are correct for 2.
  • · Replies 0 ·
  • · Replies 21 ·
