Solving Puck Collision: Speed & Direction of Puck B
The problem involves two identical pucks on an air table, where one puck (A) collides elastically with another puck (B) that is initially at rest. The objective is to determine the speed and direction of puck B after the collision, given the initial conditions and the post-collision velocity of puck A.
  • Participants discuss the need to find the resultant velocity components (Vx and Vy) for puck B, with some referencing principles of momentum and energy conservation in elastic collisions. There is also mention of using angles and energy equations to relate the velocities before and after the collision.
The discussion is active, with participants exploring different aspects of the problem. Some guidance has been provided regarding the use of conservation laws, but there is no explicit consensus on the approach to find the speed of puck B.
Participants note the challenge of determining the velocity components without having both Vx and Vy for puck B, and there is a reference to applying concepts from other physics scenarios, such as pool ball collisions.
Jtappan
Two identical pucks are on an air table. Puck A has an initial velocity of 2.6 m/s in the positive x-direction. Puck B is at rest. Puck A collides elastically with puck B and A moves off at 2.50 m/s at an angle of +16.3° above the x-axis. What is the speed and direction of puck B after the collision? (Take angles above the x-axis to be positive and below to be negative.)
_____ m/s at -73.7 °
I got the angle but I have no idea what the speed would be. Does anybody have like a ball park figure of what it would be? because the answers i get don't even make sense.
velocity is a vector so you find it by finding the resultant vector if you have the angle then you must have Vx and Vy, therefore you can find V
no i don't have Vx and Vy, i just applied the physics of pool where hitting a ball on another ball will result in a total angle of 90 degrees. So i do not know where or how to find the V.
In an elastic collision you will have conservation of momentum and energy. That gives you 3 equations to work with because you have momentum in both the x direction and perpendicular to it -- the y direction?
you've got the direction. just use a mass m for the puck. what is the total energy before the collision in terms of m. let vb be the velocity of puck B after the collision. what is the total energy after the collision in terms of m and vb...
set the energy before = energy after.
solve for vb.
  • · Replies 35 ·
