Please explain equipotential surfaces/ contour maps
The discussion revolves around the concept of equipotential surfaces and contour maps, specifically focusing on their definitions and interpretations in the context of electric potential. Participants are exploring the meaning of contour maps in relation to equipotential surfaces and the implications of line spacing on these maps.
  • The original poster seeks a simple definition of contour maps for equipotential surfaces and questions the significance of closely spaced lines. Some participants provide analogies to topographical maps to clarify the concept of changing potential.
Participants are engaging in a productive exploration of the definitions and implications of equipotential surfaces. Some guidance has been offered through analogies, but questions regarding the terminology and the meaning of "equal" in this context remain open for further discussion.
The original poster expresses confusion about the relationship between the spacing of lines on a contour map and the concept of equipotential surfaces, indicating a need for clarity on these foundational ideas.
mujadeo
Can someone please define contour map for equipotential surfaces in really simple terms.
I understand that the potential diff is from the neg side
I don't understand what it means when the lines are closer together?
I thought the lines are just divisions of the voltage, and an equipotential surface means that the potential anywhere along each individual line is uniform, but it is different from line to line (cuz your moving further or closer to the negative)
Please help!
an example:
if this is contour map, what do the close-together lines mean??
An analogy is a contour map for elevation (topographical). The closer spaced lines indicate the elevation changing more rapidly (example: hill or ravine). With equipotential surfaces, closer spaced lines indicate that potential (voltage), is changing more rapidly over distance. Here is an http://www.britannica.com/eb/art-1327/Equipotential-surfaces
Ok thanks, that helps, but now i guess I am having prob with the actual word.
"EQUI" ... --what exactlly is equal in the contour map? i am assuming equi word root means "equal"
All points along any given line have equal potential.
Just like on a map, all points on any line have equal altitude.
14K
11K
9K
