Mechanical conservation of energy
The discussion revolves around a problem involving mechanical conservation of energy, specifically analyzing the motion of a 2.5-kg object suspended from a string and released from a certain angle. Participants are exploring how to determine the tension in the string at the lowest point of the swing.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of the conservation of mechanical energy equation, questioning how to incorporate the angle of release into their calculations. There is confusion regarding the height from which the object is falling and how to express it in terms of the angle.
The discussion is active, with participants clarifying their understanding of potential and kinetic energy. Some guidance has been provided on how to determine the initial height relative to the lowest point of the swing, and there is an ongoing effort to visualize the problem through drawing.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. There is an emphasis on understanding the relationship between the angle and the height in the context of energy conservation.
gamarrapaul
A 2.5-kg object suspended from the ceiling by a string that has a length of 2.5 m is released from rest with the string 40 below the horizontal position. What is the tension in the string at the instant the object passes through its lowest position?
how do I find the velocity using mechanical conservation of energy the angle is making me confuse?
Can you begin by writing the equation for the conservation of mechanical energy?
the equation will be mgh = 1/2mv^2
the masses wil cancel out but I am not sure how to incorporate the angle
gh = 1/2 * sin(40)^2 ??
I think is wrong
Just so we're on the same page, you've decided that the ball at the bottom of the swing will have zero potential energy, and its initial kinetic energy is also zero. You've found part of the height, in other words, we're not going to use 2.5sin(40) for the height, we're interested in the balls height from the point of zero potential energy. I'm not seeing exactly how you're plugging in the numbers, it looks like you placed the value of the initial height into the speed variable.
From what you wrote, you should have the equation: [tex]v_f = \sqrt{2gh_0}[/tex]
Let's work on finding h initial, what's the relation of 2.5sin(40) to the final height? Try drawing this picture to see what I mean.
the final height will be 2.5 so 2.5sin40 is part of the height therefore to find the height we go down I need to substract 2.5 - 2.5sin40 ?
Well, 2.5 isn't the final height, zero would be the final height. This is what allowed you to make the final potential energy of the ball zero. But yes, the initial height is 2.5 - 2.5sin40. Let me know if you get hung up.
i got it thank you very much V=4.17 and T=41.8
