Discovering the Physics Behind Boiling Water's Temperature Limit
The discussion centers on the physics of boiling water, specifically the temperature limits of boiling in different pressure conditions and the effects of heat transfer in various setups. Participants explore concepts related to boiling points, pressure, and latent heat, as well as experimental observations from personal experiences.
  • Experimental/applied
  • One participant notes that water in a suspended open-topped container can reach 100 degrees C without boiling, questioning the underlying reasons.
  • Another participant explains that the water in the larger pot cannot exceed 212 degrees F due to the heat being used for vaporization, which prevents boiling in the suspended container.
  • A different participant shares an experiment where water appeared to boil in a vacuum, raising questions about the effects of reduced pressure on boiling temperature.
  • One reply clarifies that reducing pressure allows water to boil at lower temperatures, linking boiling temperature to both temperature and pressure conditions.
  • Another participant suggests that the conduction of heat from steam to the inner pot may be negligible, which could affect the experiment's outcomes.
  • Several participants express difficulty in understanding some of the concepts discussed, indicating a need for further clarification or resources.
Participants express various viewpoints on the mechanics of boiling and the effects of pressure, with some agreeing on the relationship between pressure and boiling point while others present differing experimental observations. The discussion remains unresolved regarding the implications of these observations and the underlying physics.
Participants mention the dependence of boiling temperature on pressure, but the discussion does not resolve the specific conditions or assumptions regarding the experiments described. There are also references to personal experiences that may not align with established scientific principles.
Individuals interested in the physics of phase changes, experimental setups related to boiling, and the effects of pressure on boiling points may find this discussion informative.
jlaugh87
If you suspend an open-topped container of water in a pot of boiling water, water in the inner container will reach 100 degrees C but will not boil. Why is this?
You can bring the open-topped container to equilibrium (212deg F) with the water in the larger pot, but since the water in the larger pot never gets hotter than 212 deg, the water in the suspended pot cannot boil. What's happening is that you are adding heat energy to the bigger pot, and that energy is not increasing the temperature of the water in that pot past the boiling point - the heat is being used to satisfy the latent heat of vaporization to make saturated steam at 212 deg which bubbles up (boiling).
this is kind of on the other side of this question
I was doing this in my 8th grade science class room
but we did not get a chance to finish it.
we put a cup of water into an airtight container
and slowly started to suck out all of the air and after like 5 mins the water started to look like it was boiling
with out the heat
now i can under stand the air being pulled out of the water but i am wondering after some time what would happen to the water
with out the heat
You were not pulling air out of the water. You were reducing the pressure over the water so that it would go to its vapor phase (boil) at less than boiling temperature. Boiling temperature is a function of both temperature and pressure. Large boilers are often highly pressurized so that the water will store LOTS of heat energy and not boil until the water is very hot. If you boil water on top of a mountain, it will boil at a lower temperature than 212 deg F and the offset is proportional to the ambient pressure.
that is pretty hard to understand but ok
Try this.
http://en.wikipedia.org/wiki/Boiling_point
You can also run a Google search on "boiling", "pressure", "temperature", etc. I'm sure that there are simple tutorials on the web that illustrate this.
Remember what boiling is: when the molecules of the water have enough energy to escape the loose bonds of other water molecules to fly off. That can be achieved by either
a] giving the molecules more enrrgy
b] making it easier for the molecules to escape (by lowering the air pressure above the water), or
c] both.
My Mom used the "pot floating in a pot" method to melt chocolate. One physical requirement possibly overlooked here is that the conduction of escaping steam's heat from the outer pot onto the inner pot must be negligible, which the experiment usually obeys.
thanks now i see where this is going
  • · Replies 20 ·
35K
  • · Replies 46 ·
9K
  • · Replies 32 ·
