Solving a Crane Jib Problem with Tension and Angles
The discussion revolves around a crane jib problem involving tension and angles. The scenario describes a crane with a jib of 7 meters, a center of gravity located 3 meters from the pivot point, and a load at the end of the jib. Participants are tasked with determining the tension in a horizontal tie attached to the jib while considering the forces acting on the system.
  • Mixed
  • Participants explore the moments about the pivot point A, using the equation for moments to relate the forces and distances involved. There are discussions about the correct application of trigonometric functions to find perpendicular distances and moments.
Several participants have provided insights and corrections regarding the calculation of moments and the appropriate use of sine and cosine functions. There is an ongoing exploration of the correct approach to finding the tension, with various interpretations of the geometry involved in the problem.
Participants are working under the constraints of a homework assignment, which may limit the information available for solving the problem. There are indications of confusion regarding the definitions of perpendicular distances in relation to the forces acting on the crane system.
steven10137
A crane with jib AB, 7m long. Centre of gravity 3m from A, inclined at 30 degrees to the vertical.
The horizontal tie is attached at C, 5m from A.
If the mass of the jib is 200kg and the load at B is 600kg, what is the tension in the tie.
http://img139.imageshack.us/img139/2818/cranezu9.jpg
[tex] \sum {M_{CW} } = \sum {M_{ACW} } [/tex]
OK, well if we take the pivot about the point A, we have;
[tex] \begin{array}{l}<br /> \sum {M_{CW} } = \sum {M_{ACW} } \\ <br /> \left( 3 \right)\left( {200 \times 9.8} \right) + \left( 7 \right)\left( {600 \times 9.8} \right) = \left( 5 \right)\left( {T\sin 30} \right) \\ <br /> \Rightarrow T = \frac{{5880 + 41160}}{{2.5}} = 18816N \\ <br /> \end{array}[/tex]
This tension seems very high for the system.
Could someone please explain the principle behind the Tension and angle components of the crane, because I don't think I fully understand it.
Thanks in advance
Steven.
Thanks in advance
Steven.
You are not evaluating the moments correctly. The moment of a force about a point is equal to the force times the perpendicular distance from the line of action of the force to the point.
Draw a free body diagram. That should help you see what you need to do to solve this. Its actually just a one step problem.
thanks for your reply Jay
"The moment of a force about a point is equal to the force times the perpendicular distance from the line of action of the force to the point."
So for taking the moments about the point A:
The centre of mass for the jib has moment; (3sin30)(200x9.8)
Following this procedure;
(3sin30)(200x9.8) + (7sin30)(600x9.8) = 5T
therefore T = 4704N
therefore T = 4704N
Almost there. But the perpendicular distance from the tension force tothe point is (5)sin60, right?
ya but that's not perpendicular.. that's horizontal, its COS not sin
ya exactly cos30 or sin60.. either works
OK so this perpencidular distance we are looking for the is the distance 'x' in the diagram yea?
http://img165.imageshack.us/img165/5121/craneforcepp2.jpg
cos30 = x / 5
the distance x is the 5cos30
Using this;
(3sin30)(200x9.8) + (7sin30)(600x9.8) = 5cos30T
therefore T = 5.43x10^3 N
The perpendicular distance, for each of the forces, will be the shortest distance from the green dot to each dotted line.
Its the distance to the line of action of the force, which is infinite.
cos30 = x / 5
Using this;
Correct.
excellent :)
thanks for your help Vidatu and PhanthomJay
  • · Replies 23 ·
10K
