Tangent Space of Singel layered hyperboloid
The discussion focuses on determining the tangent space of a single layered hyperboloid defined by the equation \(\left(\frac{x}{a}-\frac{z}{c}\right)\cdot\left(\frac{x}{a}+\frac{z}{c}\right)-\left(1-\frac{y}{b}\right)\cdot\left(1+\frac{y}{b}\right)=0\). The user initially struggles with using the vanishing determinant method, represented as \(\begin{vmatrix} \frac{x}{a}-\frac{z}{c} &1-\frac{y}{b} \\ 1+\frac{y}{b} & \frac{x}{a}+\frac{z}{c} \end{vmatrix}=0\), to find straight lines through points on the surface. Ultimately, the user resolves their confusion and successfully identifies the tangent space.
  • Understanding of hyperboloid geometry
  • Familiarity with determinants and Jacobians
  • Knowledge of parametric equations in multivariable calculus
  • Basic concepts of tangent spaces in differential geometry
  • Study the properties of hyperboloids and their tangent spaces
  • Learn about the application of Jacobians in multivariable calculus
  • Explore the concept of level sets in relation to surfaces
  • Investigate the use of determinants in geometric interpretations
Mathematicians, physics students, and anyone studying differential geometry or multivariable calculus, particularly those interested in the properties of hyperboloids and tangent spaces.
Mr.Brown
Tangent space of single layered hyperboloid
Ok i´m given a single layered hyperboloid given by [tex]\left(\frac{x}{a}-\frac{z}{c}\right)\cdot\left(\frac{x}{a}+\frac{z}{c}\right)-\left(1-\frac{y}{b}\right)\cdot\left(1+\frac{y}{b}\right)=0[/tex]
Now the Problem asks me to take this as a vanishing determinant, i guess they mean
[tex]\begin{vmatrix} \frac{x}{a}-\frac{z}{c} &1-\frac{y}{b} \\ 1+\frac{y}{b} & \frac{x}{a}+\frac{z}{c} \end{vmatrix}=0[/tex]
Now out of the knowledge that the surface is parametrized by a vanishing determinant i should find 2 streight lines through every point p in the surface.
Now I am totally lost how to do it by the determinant.
Im perfectly fine with just taking the tangent space at p and the just look for the direction vectors that produce lines entirely in the surface but how to do it this way.
I thought of i as a Jacobian of some function (of a,b,c ?? )for whitch the hyperboloid is sort of a level set but i don´t know how to go on sorry some hint would be fine :)
Thanks
come on you guys :)
Ok solved it :=)
