How Long Does It Take for a Block to Slow Down on an Inclined Plane?
  • Thread starter Thread starter suspenc3
    Linear
The discussion focuses on calculating the time it takes for a block projected up an inclined plane to slow down from 17 m/s to 5 m/s, given a coefficient of dynamic friction of 0.27 and an incline angle of 15˚. The initial calculation yielded an incorrect time of 3.55 seconds, while the correct answer is 1.66 seconds. Participants suggest using Newton's second law to determine acceleration and basic kinematics for time calculation, rather than relying solely on impulse and momentum methods.
  • Understanding of Newton's second law of motion
  • Familiarity with kinematic equations
  • Knowledge of forces acting on an object on an incline
  • Basic principles of friction and energy methods
  • Study the application of Newton's second law in inclined plane problems
  • Learn how to derive kinematic equations for motion on an incline
  • Explore energy conservation methods in mechanics
  • Review examples of frictional force calculations in physics
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators looking for effective teaching methods in dynamics.
suspenc3
A block A (mass m) is projected up a slope at 17 m/s. The coefficient of dynamic friction is 0.27 and θ = 15˚. How long will it take for the mass's speed to drop to 5 m/s?
**Let x direction be along the incline, y direction is normal to incline
[tex]L_1+IMP_{1-2}=L_2[/tex]
1 being point of initial velocity
2 being point of final velocity
[tex]mv_i-\mu_dNt=mv_f[/tex] (1)
sum forces in y direction:[tex]N-mgcos(\theta)[/tex] (2)
Sub 2 into 1: [tex]mv_i-\mu_dmgcos(\theta)t=mv_f[/tex]
m (MASS) cancels out and we are left with: [tex]t=\frac{v_f-v_i}{\mu_dmgcos(\theta)}[/tex]
Giving me a value of 3.55 s, whereas the answer should be 1.66 s.
Any help would be appreciated!
I would shy away from trying to solve this problem using momentum change, which is a result of the net forces acting on the object (you left out gravity), because you can get messed up very quickly. Instead, identify all the forces acting and use Newton2 to solve for the acceleration , and basic kinematics to solve for the time. Or use energy methods if you're familiar with that approach.
Yea, It is a bit safer your way, and I got it using Impulse/Momentum change too, Thanks for your help Phanthom
  • · Replies 18 ·
