| Thread Closed |
what is the nature of gravity constant? |
Share Thread | Thread Tools |
| Nov11-07, 06:36 PM | #1 |
i just ask that? and if we can know the nature of it can we understand the meaning of gravity? |
| Nov11-07, 08:05 PM | #2 |
Mentor
Huh? The gravitational constant? It is number. A physical constant.
Physicists look for order, they don't look for "meaning". "Meaning" doesn't really mean anything anyway. |
| Nov12-07, 12:38 PM | #3 |
| Nov12-07, 10:29 PM | #4 |
The units of Big G, the so called "Gravitational Constant" are most interesting: cubic meters per second squared per kilogram. Translated, this means Volumetric Acceleration per unit mass. The first thing that might occur to one looking at this is why would the volumetric accelertion be the same for a much smaller universe, say one only the size of a basketball as compared to one having a Hubble radius of 10^26 meters. The other thing that should be suggested is how do you get the number 6.67 x 10^-11 out of what we think we know about the size and rate of expansion of the cosmos. Specifically, how does the volumetric acceleration come into being if the Hubble expansion rate is uniform?
| Nov15-07, 09:31 AM | #5 |
The gravitational constant is equal to (3Pi/4)H(squared)/density of matter in the universe. I hope this helps.
| Nov15-07, 12:50 PM | #6 |
Hi gamburch
How did you arrive at this - I assume you used Friedmann's relationship that relates G and density. If the universe has critical density mass - then the factor would be 3pi/8 rather than 3pi/4. Yogi |
| Nov15-07, 01:50 PM | #7 |
[tex] G = \frac{3 \pi}{4} \frac{H^2}{\rho} [/tex] ?? where [itex]\rho[/itex] is the "density of matter in the universe". if so, can you identify H? |
| Nov15-07, 03:18 PM | #8 |
Recognitions:
This appears to be an incorrect derivation from The Friedmann equations.
The correct expression would be [tex]G = \frac{3 H^2}{8 \pi \rho}[/tex] In any event, this equation is not always true - it requires that the cosmological constant [itex]\Lambda[/itex] be zero, that the spatial curvature of the universe K=0, and of course the assumptions that GR is correct and the cosmological principle holds so that the universe is homogenoeus and isotropic. H here would be Hubble's constant. |
| Nov15-07, 08:05 PM | #9 |
Recognitions:
I've moved a post by rbj to the cosmology forum as a new thread http://www.physicsforums.com/showthread.php?t=198513
| Nov16-07, 04:07 AM | #10 |
Yogi: Thanks for your interest. Gravitational potential has the units of velocity squared. If one uses the value of the density of matter of the universe published by Peeblers some time ago, one can compute the gravitational potential locally arising from all matter in the universe by merely integrating over a sphere of size equal to the speed of light divided by the Hubble constant. This computation yields a number close to the speed of light squared. I like this way of doing things because it rather nicely explains the relationship of mass to energy; the potential times the matter being the cost of its assembly.
If in the computation one substitutes c/H for the radius one has c squared on both sides yielding a relationship between the gravitational constant, the density of the universe and Hubble's constant. The constant in the equation comes from the volume of the sphere and has no magic. A more careful worker than I would have accounted for the Doppler effect on the local field so the criticisms of my simple computation are probably very apt. I did not get the equation from elsewhere, however. What you see is what you get. |
| Nov17-07, 12:40 AM | #11 |
Interesting Gamburch. I have seen the same formula derived using Hubble's law v = Hr, the procudure the poster used was to differentiate and plug in the value v = c at the Hubble limit getting dv/dt = Hc and then re substituting c = Hr giving an effective acceleration = (H^2)R If I remember, the fellow actually got the paper published in an electronics magazine - probably because he extrapolated the result in terms of electric fields, which I could never figure out. Maybe I can dig up the old thread, you might be interested.
regards yogi |
| Nov17-07, 01:09 AM | #12 |
This is a follow-up to post 11. I don't think the old thread is still available - at least I can't find it - but here is the rest of what the poster did - he sets the force of gravity GMm'/R^2 equal to the F = m'a force. For "a" he uses the (H^2)/R that he derived from from Hubbles law - so he sets (GM/R^2) = (H^2)R where M is the mass of the universe
and since M = V(rho) and V = 4/3(pi)R^3 .....vola, G = [3/4(pi)](H^2) I am sure the math types will have nothing but condemnation for this sort of procedure but I think these simple relationships are telling us something about the universe that is being overlooked |
| Nov17-07, 04:02 AM | #13 |
Thank you Yogi. I truly appreciate this recollection and will be mulling it over; however, today is the day for starting my Christmas home brew. I'll be back soon. Thanks again.
| Nov17-07, 07:22 PM | #14 |
Home Brew - sounds like something with profound cosmological intrigue. When we talk later I will show you my own derivation of G - and some consequences thereof. Seems there are many ways to skin the same cat.
Happy Holidays Yogi |
| Dec24-08, 05:57 PM | #15 |
I have almost the same question as this one of Freesom. It is known what means G in Newtonian gravity. (for instance: acceleration 1 m from 1 kg heavy (point) ball) Maybe there is something still more clear. But, did G get any clearer meaning in Einsteinian curved space?
"Physicists look for order, they don't look for "meaning". "Meaning" doesn't really mean anything anyway." I never agreed with this style of thinking. This style make unclear, what can be easily clear. |
| Dec24-08, 08:27 PM | #16 |
Mentor
| Dec25-08, 07:49 AM | #17 |
Mentor
In both theories G has the same role. GR made two principle improvements over Newtonian gravity. First, it is more general, applying in situations where Newtonian gravity was wrong (Mercury) or unclear (bending light). Second, it makes the relationship between inertia and gravitation more clear (equivalence of gravitational and inertial mass).
G itself, as a dimensionful constant, can be seen as simply relating different units. You cannot really attach any physical significance to any dimensionful constant as anything other than a unit conversion. This independent of which theory you use. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: what is the nature of gravity constant?
| The Nature of Gravity | Special & General Relativity | 9 | ||
| Hypothesis for the nature of gravity | General Physics | 26 | ||
| Nature of the cosmological constant | Special & General Relativity | 6 | ||
| Scientific american article about the nature of gravity. | General Physics | 35 | ||
| Fine structure constant has geometrical nature | General Physics | 2 | ||
