Surjective group homomorphism
  • Thread starter Thread starter e12514
    Group Surjective
The problem involves demonstrating that a specific map, defined from the group of unitary matrices (U_n) to the set of nonzero complex numbers (C*), is a surjective homomorphism. The map is defined by taking the determinant of matrices in U_n, and the challenge lies in showing that for every nonzero complex number, there exists a corresponding unitary matrix whose determinant equals that number.
  • Exploratory, Assumption checking
  • One participant verifies the homomorphism property of the map but expresses difficulty in proving surjectivity. They note that for surjectivity, a unitary matrix must exist for every nonzero complex number, raising concerns about the nature of unitary matrices and their determinants.
  • Another participant asserts that the determinant of a unitary matrix lies on the unit circle, suggesting that the map cannot be surjective.
  • Further discussion includes questioning the definition of C* and considering the possibility of a typo in the problem statement.
  • Participants explore the implications of the determinant being restricted to the unit circle and whether this aligns with the original problem's intent.
The discussion is ongoing, with participants exploring the implications of the properties of unitary matrices and their determinants. There is no explicit consensus yet, but the questioning of assumptions and potential typographical errors indicates a productive examination of the problem.
Participants are considering the constraints imposed by the definition of unitary matrices and the nature of their determinants, particularly in relation to the set C*. There is uncertainty regarding the interpretation of C* and its implications for the surjectivity of the map.
e12514
Show the map (call it phi) from U_n to C*
defined by phi(X) = det(X) for all matrices X in U_n,
is a surjective homomorphism, where
U_n is the subgroup of GL(n,C) consisting of unitary matrices
C* = C\{0} = invertible/nonzero complex numbers
det(.) is the determinant of .
A matrix X in GL(n,C) is unitary if ((X_bar)^T).X = I
where X_bar is the conjugate of X (taking the conjugate of each entry in X)
Homomorphism is easy to verify:
phi(XY) = det(XY) = det(X) det(Y) = phi(X) phi(Y)
I'm having trouble showing it's surjective.
For it to be surjective we need
for all (a+bi) in C* there exists X in U_n such that phi(X) = det(X) = a+bi
where a and b not both zero
The problem is X needs to be unitary, that is, X-conjugate-transpose times X needs to be the identity matrix.
It follows the the required matrix X can't be a diagonal matrix, otherwise it is not unitary if its determinant is (a+bi), in particular every entry on that diagonal where there's a complex number x+yi, that entry will become (x^2 + y^2) after taking ((X_bar)^T).X instead of the required "1" on the diagonal of an identity matrix.
Similarly I couldn't get anywhere with triangular matrices, and any non-diagonal and non-triangular matrix seems to get too complicated, not to mention that triangular matrices are messy enough...
It's definitely not going to be surjective -- the determinant of a unitary matrix lies on the unit circle.
Hmm... that's true. Maybe there was a typo on the question.
Unless there is some other interpretation for what C* is...
Maybe it was indeed meant that
C* = { z \in C : ||z|| = 1 }
