Calculating Delta Heat of Formation: Alternatives and Limitations
The discussion centers on calculating the delta heat of formation for the reaction H2 + CuSO4(aq) ---> Cu(s) + H2SO4. Participants clarify that direct formation of H2SO4 is not feasible due to material constraints. It is established that the enthalpy change of formation cannot be determined for this reaction as it does not produce H2SO4 from its elemental states. Instead, alternative methods such as Hess' Law and measuring temperature changes before and after the reaction are suggested for calculating energy changes.
  • Understanding of delta heat of formation and enthalpy changes
  • Knowledge of Hess' Law for thermodynamic calculations
  • Familiarity with half-reaction methods in electrochemistry
  • Basic principles of calorimetry for measuring temperature changes
  • Research Hess' Law applications in thermochemistry
  • Learn about calorimetry techniques for measuring heat changes
  • Study the enthalpy change of formation for common compounds
  • Explore alternative reactions for calculating delta heat of formation
Chemistry students, educators, and researchers interested in thermodynamics and reaction energetics, particularly those studying delta heat of formation and calorimetry techniques.
masterblah777
Currently I am enrolled in college level General Chemistry course, and at this time we are working on a project to figure out the delta heat for formation of a specific reaction.
The equation is this
We have gone through and determined the half reactions for finding the Delta heat for formation. But we are not allowed to create H2SO4 directly because we don't posses the materials for the environment. We know how to create CuSO4 but we do not know how to react the Cu and S04.
Is there an alternate solution to figuring out the delta heat of formation for CuSO4 and H2SO4? Those are the only two heats of formation we need to get in order to solve for the delta heat of formation for the entire reaction. Possibly different reactions to find the delta heats of formation?
Chemistry news on Phys.org
Sorry, it's difficult for me to understand exactly what data you can use and what you can't.
Furthermore, what means "We have gone through and determined the half reactions for finding the Delta heat for formation" and "We know how to create CuSO4 but we do not know how to react the Cu and S04"?
Sorry, it's probably my difficulty in understanding your terminology.
if I'm not wrong, this reaction ain't supposed to be occurring. H2 will not react with Cu2+.
you can't determine enthalpy change of formation in this reaction. the enthalpy change of formation is when 1 mol of a compound is produced from its elements in their elemental states.
e.g. enthalpy change of CO2:
C + O2 -----> CO2
the energy change in this reaction gives the enthalpy change of formation of CO2.maybe you're referring to simply the enthalpy change of this reaction, which isn't supposed to occur??!
Then you may use Hess' Law. Or you could measure initial and final temperature before and after reaction and calculate the heat energy liberated. But i doubt it will work. I'm just saying this to tell you the methods to calculate energy changes.
  • · Replies 131 ·
11K
34K
  • · Replies 19 ·
  • · Replies 25 ·
