PH problem weak acid and weak base
The discussion focuses on calculating the pH of a buffer solution composed of 6.90 g of NaH2PO4 and 5.70 g of Na2HPO4 in 355 mL of solution. To determine the pH, the Henderson-Hasselbalch Equation is applied: pH = pKa + log ([A^{-}] / [HA]). Participants emphasized the need to calculate the molarity of both the acid (NaH2PO4) and the base (Na2HPO4) using their respective molar masses, and to find the pKa of phosphoric acid using its acidity constant (Ka).
  • Understanding of the Henderson-Hasselbalch Equation
  • Knowledge of molarity calculations
  • Familiarity with acid-base chemistry, specifically phosphoric acid
  • Ability to calculate pKa from Ka values
  • Calculate the molar mass of NaH2PO4 and Na2HPO4
  • Determine the acidity constant (Ka) of phosphoric acid
  • Practice using the Henderson-Hasselbalch Equation with different buffer solutions
  • Explore the applications of buffer solutions in various chemical contexts
Chemistry students, laboratory technicians, and anyone involved in buffer solution preparation and pH calculations.
hsgnfgkid
Hi
I have been trying several days to solve this problem. But i can't find the procedure to solve this weak acid and weak base problem. I will really appreciate some help.
What is the pH of a soft drink in which the major buffer ingredients are 6.90 g of NaH2PO4 and 5.70 g of Na2HPO4 per 355 mL of solution?
Thanks:smile:
Chemistry news on Phys.org
To find the pH of a buffer solution, you use the Henderson-Hasselbach Equation:
pH = pKa + log ([[tex]A^{-}[/tex]] / [HA])
[[tex]A^{-}[/tex]] is the molarity of your conjugate base
[HA] is the molarity of your acid
So you want to find the concentration of acid and base in your buffer solution. Keep in mind that NaH2PO4 is your acid and Na2HPO4 is your base.
Also, you need the Ka (acidity constant) of phosphoric acid (I don't know this off the top of my head).
Before anything else, I would find the molarity of each solution. I'm sure you know how to do this, but if not, find the molar mass of each compound and plug into the following equations:
# moles = grams / molar mass (in g/mol) and Molarity = Moles / Liters
Once you have the molarity of each compound and the Ka of phosphoric acid, find the pKa of phosphoric acid by doing:
pKa = -log(ka)
So, plug these values into the Henderson-Hasselbach equation and you'll be all set.
Hi Staf9
I would really want to thank you for th answer. Youre the best, really i appreciate your work. THANKS ONCE AGAIN
9K
