Confusing gases, help with lab report needed
The discussion revolves around a lab report concerning the relationship between pressure and mass of air in a glass container under varying conditions. The original poster describes conducting experiments to gather pressure-mass readings and attempts to derive a formula for mass as a function of pressure, while facing challenges in determining the density of air due to unknown volume and molar mass of humid air.
  • Exploratory, Assumption checking
  • Participants discuss measuring the container's volume and how it relates to calculating density. There is a suggestion to consider the effects of temperature and humidity on air density, as well as the importance of careful observation in experiments.
The conversation has progressed with the original poster realizing the volume was known, which alleviated some confusion. Guidance has been offered regarding the relationship between mass, density, and volume, but no explicit consensus has been reached on the broader implications of the findings.
Participants note the original poster's initial oversight regarding the known volume of the container, which impacted their calculations. There is also mention of humidity affecting the weight of air, which remains a point of consideration in the discussion.
sickboy
Hi all! This what I've done: First I pumped underpressure into a glass container, checked the manometer's reading and then weighed the container on two different scales. Then I opened the valve a bit, checked pressure and weighed the bottle etc. I did this 10 times. So what I've got is 10 pressure-mass readings.
Now the report part. I first had to draw a measured points into (p,m)-coordinate grid. Then I did linear regression and derived a formula:
m=(VM)/(RT)*p
so m is a function of p. With the slope (VM/RT) I could determine the mass of the air inside the bottle in room temperature and in NTP. No problems here. Next, they want me to determine the density of air with the help of VM/RT and the mass of air. It would be a fairly easy calculation if I knew the volume of the container, but I don't. Also, the molar mass of humid air (humidity 40%) is unknown.
I'm completely stuck on this one. A prod into the right direction would be greatly appreciated!
Well, I doubt I will be very helpful, but no one else is helping you yet.
Can you measure the container and make a guess as to the volume?
This may or may not be helpful: Density of Dry air at 10 degrees C is 0.00125 g per cc.
At 30 C, it's 0.00116.
Since you found out the mass and the density can be found depending on the temp, you can get the volume? Take away the weight of the container? And remembering that the more humid the air, the less weight, right? Because the tiny water molecules weigh less than dry air. Something like that.
Good luck.
Thanks for your input. The values you gave seem to agree with those I got. It seems I did a pretty stupid mistake, the volume WAS known - I just hadn't noticed it. It was written on the container. Well, the rest of the report wasn't that hard, and I've got it done now.
God, I feel stupid.. :frown:
Don't beat yourself up for not noticing something. Now you will probably always be very observant, so it was a good lesson to learn, right? I know one thing; I look at mechanical things and tools very closely, and doing so enables me to understand what they are used for and how to handle them. I look over my physics labs stuff very, very carefully before I go ahead with the experiment, and so far that's been very helpful.
Good luck for the rest of the semester!
