Clamping Circuits: Get 8V Output from 2V Input
  • Thread starter Thread starter nikhilesh
    Circuits
The discussion centers on enhancing a negative clamper circuit to achieve an 8V output from a 2V input. The user currently employs a simple capacitor and diode setup that clamps the sinusoidal wave to 0-4V. To achieve the desired output, the user is advised to explore a voltage doubler circuit, which also utilizes capacitors and diodes. Resources provided include links to a voltage multiplier theory and a diode application guide for further understanding.
  • Understanding of negative clamper circuits
  • Basic knowledge of voltage doubler circuits
  • Familiarity with capacitors and diodes in AC applications
  • Ability to analyze sinusoidal waveforms
  • Research voltage doubler circuit designs and configurations
  • Study the operation of capacitors and diodes in AC circuits
  • Learn about the implications of clamping on average voltage values
  • Explore practical applications of voltage multipliers in electronics
Electronics students, hobbyists working on circuit design, and engineers looking to implement voltage multipliers in their projects.
nikhilesh
I have a negative clamper with a simple capacitor and a single diode. This circuit clamps the Sinusoidal wave (2V- peak to peak) to the negative peaks and makes the output (0 to 4V) ..
My question is how do i make the output signal 8V using the same input and more or less the same circuit.. my teacher says its possible.. I can't get how..
Help Me! :)
Mayb a voltage doubler? A simple one requires a capacitor and diode which is more or less the components you have available.
http://www.play-hookey.com/ac_theory/ps_v_multipliers.html
http://www.kettering.edu/~bguru/DIODE/Diode-10.pdf (PDF file)
i dont' know.. seems okay. will ask the teacher. i need an output 4 times the input. clamper increases the average value of a sinusoidal input from 0 to V.. i need it raise to 2V
  • · Replies 78 ·
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 16 ·
