How Does Doubling Capacitance Affect Voltage Distribution in a Series Circuit?
  • Thread starter Thread starter ortin
    Capacitance
In a series circuit with three capacitors, where two capacitors have a capacitance of C and the middle capacitor has a capacitance of 2C, the voltage distribution changes significantly. Initially, the voltage across each capacitor is V/3. When the middle capacitor's value is doubled, the voltage across it becomes V/2, while the voltages across the other two capacitors remain V/4 each. This results in a total voltage of V, confirming Kirchhoff's law and the relationship between charge and capacitance.
  • Understanding of Kirchhoff's laws
  • Familiarity with capacitor equations, specifically Q = CV
  • Basic knowledge of series circuits
  • Concept of voltage distribution in electrical circuits
  • Study the implications of changing capacitance in series circuits
  • Learn about the effects of capacitor configurations on voltage distribution
  • Explore advanced topics in electrostatics, focusing on charge distribution
  • Investigate practical applications of capacitors in electronic circuits
Electrical engineering students, educators teaching circuit theory, and professionals working with electronic circuit design will benefit from this discussion.
ortin
1. Three equal capacitors, all with values C, are in series with a battery of V volts. If the middle capacitor is changed to 2C, what will be the resultant potential across each capicitor? Express your answer in terms of V.
C = Q / V
Initially, when the capacitors are equal, the total voltage will be distrubuted evenly over the capacitors (Kirchhoffs law). Therefore the potential over each = V / 3
If one of the capacitors value is doubled, then following the relation V = Q /C, the potential diffence of the middle capacitor will be halved.
End of attempt
However the next question goes on to discuss the affect of this on the charge per plate. By rearrangement - Q = VC, so if the capacitance is doubled, so should the charge. But then this contradicts the value for V previoulsy found?
Many Thanks!
The PEs across each of the capacitors have changed, in such a way that the sum is V. The new PE across 1 and 3 is the same, say V1 (by symmetry). The new PE across the middle one is now V2.
V=2V1+V2.
Suppose C was the capacitance of each at first. The middle one is 2C now.
Now, the charge in the middle one must be equal to the charge of 1st. Using this, what do you get?
  • · Replies 28 ·
