Relative Brightness of A-E, C+D
The discussion centers on the relative brightness of five light bulbs (A, B, C, D, and E) arranged in a combination of series and parallel connections. Light bulbs C and D are connected in series, while they are in parallel with bulb E. Bulbs A and B are connected in parallel. The consensus is that if all bulbs are identical, their brightness can be expressed as A=B=E=C+D, assuming identical wattage. However, variations in individual wattage ratings could alter this conclusion.
  • Understanding of electrical circuit configurations (series and parallel connections)
  • Knowledge of Ohm's Law and power calculations
  • Familiarity with concepts of current and voltage dividers
  • Basic principles of light bulb wattage and brightness correlation
  • Research the effects of series vs. parallel connections on circuit behavior
  • Learn about calculating total resistance in series and parallel circuits
  • Explore the relationship between wattage and brightness in incandescent and LED bulbs
  • Study the application of Ohm's Law in practical circuit analysis
This discussion is beneficial for electrical engineering students, hobbyists working with circuits, and anyone interested in understanding the principles of electrical brightness in light bulb configurations.
Empire
There are five light bulbs. Light bulb C and D are in a series connection. C and D are in a parallel connection with E. Light Bulb A and B are in a parallel connection. The two parallel connections are wired in a series connection. What would be their relative brightness? I'm thinking that A=B=E=C+D
|----power---------------|
|**|--A--|***|-C-D-|**|
***|--B--|***|--E--|***
First you have to make at least one assumption. I would assume that the light bulbs are identical, and that "brightness" means "total power emited". Then brightness ~ I2.
I disagree with your result (assuming I did it correctly). You need to use the voltage and current divider to examine this circuit.
The relative brightness of A, B, E, C, and D would depend on the individual wattage or power rating of each light bulb. However, in general, A, B, and E would have the same brightness because they are in a parallel connection. C and D, being in a series connection, would have the same brightness as each other but potentially different from A, B, and E. Therefore, the relative brightness of A, B, E, C, and D would be A=B=E=C+D. However, this could change if the individual wattage of each light bulb is different.
