Chemistry - Adding Strong Acid to Buffer
The discussion centers on calculating the pH change of an acetic acid buffer after the addition of 7.80 mL of a 0.400 M strong acid, specifically HCl. The initial buffer solution has a pH of 5.00, with a total molarity of 0.1 M for the acid and conjugate base. The Henderson-Hasselbalch equation is applied, revealing an initial ratio of base to acid that was incorrectly calculated, leading to an erroneous pH change of -0.40. Correcting the ratio of [A-] to [HA] is essential for accurate pH change determination.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of buffer solutions and their components
  • Familiarity with molarity and mole calculations
  • Basic concepts of acid-base chemistry
  • Review the Henderson-Hasselbalch equation for buffer calculations
  • Learn about the properties and calculations involving acetic acid buffers
  • Study the impact of strong acids on buffer systems
  • Explore detailed examples of pH calculations in buffer solutions
Chemistry students, educators, and professionals involved in laboratory work or academic research focusing on acid-base chemistry and buffer systems.
sam.
A beaker with 135 mL of an acetic acid buffer with a pH of 5.00 is sitting on a benchtop. The total molarity of acid and conjugate base in this buffer is 0.1 M. A student adds 7.80 mL of a 0.400 M solution to the beaker. How much will the pH change? The pKa of acetic acid is 4.76.
Henderson-Hasselbach equation: pH = pKa + log([base]/[acid])
hat I did was find the total number of moles of acid + base = 0.0135. Then using the pH = pKa + log([base]/[acid]) I found the ratio of [base]/[acid] to be 1.74. Then using these two equations I found the moles of acid to be 4.93*10^-3 and base = 5.45*10^-3. Next I found the moles of HCl = 0.00312 mol and substracted that from the base and added it to the acid so: acid = 8.05*10^-3 and base = 5.45*10^-3. Now I put these values into pH = pKa + log([base]/[acid]) and got the pH to be 4.59...therefore the change would be -0.40...But I think this value is too high...I think it's supposed to be lower. Can anyone tell me where I went wrong? Any help is appreciated.
7.80 mL of a 0.400 M solution of what? Possibly a strong acid? I'll assume it is a strong acid (HCl).
What I did was find the total number of moles of acid + base = 0.0135.
No. What does your question say about the total concentration of the acid [HA] and conjugate base[A-]? It isn't 0.0135.
This part is right.
... and substracted that from the base and added it to the acid so: acid = 8.05*10^-3 and base = 5.45*10^-3. Now I put these values into pH = pKa + log([base]/[acid]) and got the pH to be 4.59...therefore the change would be -0.40...But I think this value is too high...I think it's supposed to be lower. Can anyone tell me where I went wrong? Any help is appreciated.
Your logic is sound here but you used the wrong value for the ratio of [A-]/[HA]. Can you calculate initial [A-] given only the initial pH? You should also keep in mind that [A-](initial) + [HA](initial) = 0.1 and that total doesn't change throughout the problem, only the individual values of [A-] and [HA].
Hope it helps.
  • · Replies 23 ·
