What Are the Correct Units for Weight?
  • Thread starter Thread starter pyroknife
    Units Weight
The discussion revolves around the correct units for weight, specifically exploring the options of kilograms, Newtons, and the expression kg(m/s²). Participants are examining the relationship between these units and their definitions in the context of physics.
  • Some participants assert that the correct answer includes both Newtons and the expression kg(m/s²), while others provide reasoning about the definitions of force and weight. There are questions regarding the notation used in expressing units, particularly the interpretation of the multiplication sign.
Participants are actively engaging with the definitions and relationships between the units of weight. There is a recognition that both Newtons and kg(m/s²) are valid representations of weight, but no explicit consensus has been reached on the phrasing of the answer. The discussion includes clarifications about unit notation.
Participants are working within the framework of standard SI units and are questioning the implications of unit notation in the context of physics. There is a focus on ensuring clarity in understanding the definitions and relationships among the units discussed.
pyroknife
The units for weight are
A)kg
B) Newtons
c) kg(m/s^2), the 2 means squared
d) both b and c
i believe the the answer is d am i right?
A)kg
B) Newtons
d) both b and c
You are correct.
Newton (N) is a measure of force.
Also force F is the product of mass (m) and acceleration (a). Unit of mass in SI/mks is kg, and unit of acceleration is m/s2 or units of force are kg-m/s2.
The definition of 1 N is 1 kg-m/s2.
you are correct
A)kg
B) Newtons
d) both b and c
In fact, choice (c) gives the fundamental units for Newtons, so choice (b) is really the same. So (d) would be correct.
Astronuc said:
You are correct.
when you typed "kg-m/s^s" does this "-" mean minus or multiplying?
pyroknife said:
when you typed "kg-m/s^2" does this "-" mean minus or multiplying?
When applied to units, that is a commonly used notation to indicate multiplication.
  • · Replies 29 ·
24K
