A Rate of change and a differentials problem
The discussion focuses on two calculus problems involving rates of change and differentials. The first problem involves the position function X(t) = t³ - 6t² + 8t, where participants analyze the particle's direction of movement, acceleration at zero speed, and total distance traveled from t=0 to t=2. The second problem addresses the maximum error in estimating the height of a building based on an angle of elevation of 75 degrees, incorporating the formula h = 30ft * tan(a) and the differential error calculation Δh = (1 + tan(a)²) Δa. Both problems require a solid understanding of derivatives and trigonometric functions.
  • Understanding of calculus concepts, specifically derivatives and integrals.
  • Familiarity with trigonometric functions and their applications.
  • Knowledge of error analysis in measurements and calculations.
  • Ability to apply the law of sines and tangents in real-world problems.
  • Study the application of derivatives in motion problems, focusing on velocity and acceleration.
  • Learn about error propagation in trigonometric measurements and its implications.
  • Explore the law of sines and its applications in height estimation problems.
  • Practice solving similar calculus problems involving rates of change and differentials.
This discussion is beneficial for students studying calculus, particularly those focusing on motion analysis and error estimation in trigonometric contexts. It is also useful for educators seeking examples of real-world applications of calculus concepts.
aaroffl
First off i'd like to say Hi to the forums, hehe. I didn't really see a new member area but I suppose this will do. Right now I'm kind of struggling with these two problems that I recently took a quiz on and didn't do so well. I've been trying to figure out how to work them out but i just don't really get it. if anyone could help out it'd be awesome.
(1)
The position (in cm) of a particle along the x-axis at time t(in s) is given by X(t) = t^3-6t^2+8t, t is greater than or equal to 0.
the question:
When is the particle moving to the left? the right?
Acceleration of the particle when the speed is zero.
Total distance traveled from t=0 to t=2.
(2)
( and the one that REALLY gets me)
A person standing 30ft from the base of a building measures the angle of elevation to the top of the building as being 75 degrees with an error of +or- 1.2 degrees.
What is the max error in estimating the height of the building, and the percentage error?
This one has taken me quite a while, I am thinking it has something to do with the law of sines, but when i try it with that method I'm getting a completely unreasonable answer. I kind of have the right idea, i hope, but for some reason I'm just not seeing it.
Thank you in advance for those who wish to take on these.
(1.) Let x' be the first derivative with respect to t, x'' the second.
a.) Right when x'>0, left when x'<0.
b.) Find at what time t the velocity x'=0, and then substitute this into x''.
c.) compute x(2)-x(0)
(2.) If you know the angle of elevation, a, the height of the building is given by
h = 30ft * tg(a)
Now the error in your case is given by Delta a = +-1.2 degrees = +- 0.02 radians, and the resulting error in h is:
[tex]\Delta h = (1+\tan(a)^2) \Delta a[/tex]
(If you need further explanations on that one, ask.)
Now you merely need to substitute.
Good luck!
Assaf
http://www.physicallyincorrect.com/"
  • · Replies 18 ·
