Calculate Components of Hammer's Velocity at Edge of Roof
The discussion focuses on calculating the components of a hammer's velocity as it slides down a roof inclined at 32.0 degrees. The hammer's speed is given as 6.25 meters per second. The correct calculations yield a horizontal velocity component (Vx) of 5.21 m/s and a vertical velocity component (Vy) of 3.44 m/s. The confusion arose from the inclusion of angles in the calculations, which are not necessary for determining the magnitudes of the velocity components.
  • Understanding of basic trigonometric functions (sine and cosine)
  • Knowledge of vector decomposition in physics
  • Familiarity with the concept of velocity components
  • Ability to perform calculations involving angles in right triangles
  • Study vector decomposition techniques in physics
  • Learn about the application of trigonometric functions in real-world scenarios
  • Explore problems involving inclined planes and motion
  • Review the principles of projectile motion and its components
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators seeking to clarify concepts related to velocity components and trigonometry.
murfzee0224
1. A hammer slides down a roof that makes a 32.0 degree angle with the horizontal.
2. a.) What are the magnitudes of the components of the hammer's velocity at the edge of the roof if it is moving at a speed of 6.25 meters per second?
b.) Calculate the components of the hammer's velocity at the edge of the roof.
3. I drew a picture for this problem and the teacher said it was right, but I don't know what to do from there. I ended up forcing numbers and have current answers of Vy = 6.25 sin 32.0 (3.44 m/s) with a magnitude of 32 degrees and Vx = 6.25 cos 32.0 (5.21 m/s) with a magnitude of 58 degrees.
PLEASE HELP ME! I know that what I have is wrong. I have checked my notes, the book, and classwork for a problem similar to this and I've had no luck. The teacher will not give anymore hints and my classmates haven't made any progress. Any help is appreciated, thanks!
Yes, the hammer has a horizontal velocity component of 5.21m/s and a vertical downward velocity component of 3.44m/s. You have calculated those components correctly based on the given angle; why are you including angles in your calculated velocity components?
Thanks for the help. I included the angles because I thought that they may have been the components' magnitudes.
