Calculate Final Temp of Thin Steel Piece: Heat Transfer Problem
  • Context: Undergrad
  • Thread starter Thread starter JJ420
    Heat Heat transfer
This discussion focuses on calculating the final temperature of a thin steel piece subjected to a heat flux of 3000 W/m². The initial temperature is set at 20°C, and the thermal properties include a thermal conductivity (K) of 51.9 W/m·K and a specific heat (C) of 0.472 kJ/kg·K. The transient conduction problem simplifies by considering the temperature after approximately 0.1 seconds, leading to a calculated temperature increase of about 0.1°C based on the energy input of 300 J/m².
  • Understanding of transient heat conduction principles
  • Familiarity with thermal properties of materials (thermal conductivity, specific heat)
  • Basic knowledge of heat transfer calculations
  • Ability to interpret scientific papers related to heat transfer
  • Study the paper "Heating of Solid Targets with Laser Pulses" by Bechtel for advanced insights
  • Learn about thermal diffusivity and its role in heat transfer calculations
  • Research methods for calculating temperature changes in transient conduction scenarios
  • Explore numerical methods for solving heat transfer problems in engineering applications
Engineers, physicists, and researchers involved in thermal analysis, particularly those working with heat transfer in metals and laser heating applications.
JJ420
First off I would like to say that this is not a homework question. I am trying to calculate the temperature of a very thin piece of steel.
Assumptions
The underside of the metal is perfectly insulated
To = 20C (initial temperature of material)
Q"=3000W/m^2 (heat flux)
K = 51.9W/m*K (thermal conductivity)
C = .472 KJ/Kg*K ( specific heat)
x = 1mm ( thickness of metal)
t = 0.1s
What I need to know is how to calculate the final temperature at the surface.
Science news on Phys.org
Am I right in thinking you are doing some laser heating here? if so you should look at
the paper written by Bechtel "heating of solid targets with laser pulses" . Also check out the citations there are a lot of papers out there that solve this kind of problem
This is a transient conduction problem that can be made much easier by assuming you only need to know the temperature about a second after the heat flux is turned off, not before. The reason is that the characteristic diffusion time through 1 mm of steel is about a tenth of a second:
[tex]t\approx\frac{h^2}{D}=\frac{h^2 c \rho}{k}\approx 0.1\,\mathrm{sec}[/tex]
where D is the thermal diffusivity and h is the thickness, and I've used your numbers. After about a second, the temperature will have become nearly uniform in the plate, and the temperature increase can be calculated by considering the amount of input energy: 300 J/m2.
[tex]\Delta T=\frac{E}{c\rho h}[/tex]
I get about a tenth of a degree Celsius for the temperature increase. Does this help?
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 25 ·
