Calculating Centre of Mass on a Board on Ice
The problem involves calculating the center of mass of a system consisting of a person standing on a board resting on a frictionless ice surface. The person moves from one end of the board to the center, and the task is to determine how far they have moved relative to their starting position on the ice.
  • Exploratory, Assumption checking
  • Participants discuss the calculation of the center of mass and the implications of movement on a frictionless surface. There is a focus on the relationship between the movement of the person and the board, with some questioning the correctness of their answers and reasoning.
Participants are exploring different interpretations of the problem, particularly regarding the movement of the board in response to the person's movement. Some guidance has been offered regarding the implications of the frictionless surface, and there is an ongoing examination of the calculations involved.
There is some uncertainty regarding the assumptions made about the system's behavior, particularly in relation to the movement of the board and the person. Participants are encouraged to clarify their reasoning and check their calculations.
Omnie
Board on Ice
1. A person of mass M is standing at one end of a board of mass m and length l. The board rests upon a frictionless ice surface and it's mass is uniformly distributed along its length. Calculate how far from the person, d, the centre of mass is of the system. The person then walks to the centre of the board and stops (assuming friction is enough). How far from his starting position (relative to the ice surface) has he moved?
2. centre of mass = 1/M[tex]\Sigma[/tex]mr
All right, the centre of mass is easy to calculate and it's just (ml)/(2(M+m) and I didn't have problems with that. It's the next part which I am unsure of the correct answer. My friends have got an answer of (ml)/(2(M+m) as his total distance moved but I get a slightly different answer of (l/2)(1 - (m)/(M+m)).
My reasoning is that it has to be slightly less then (l/2) as he walks that distance on the board but the board has moved in the opposite direction so the distance from the original starting point is slightly less.
The answer of (ml)/(2(M+m)) seems obvious and I'm not 100% it's that or am I just over thinking a simple question?
Thanks.
Your friends are wrong. As the surface is frictionless, there are no horizontal forces acting on the (man+board) system. Hence, as the person's CM moves to the left (say he was standing on the right end of the board), the board must move to the right. Hence, the person and the board "meet somewhere in the middle". Sort of a conveyor belt.
See if this new insight helps you with your solution.
Assaf
http://www.physicallyincorrect.com/"
Assaf
Yah, that's exactly the reasoning I used to get an answer of (l/2)(1 - (m)/(2(M+m)). I'll try to recheck my answer again to see if I've made any mistake. Thanks for the help. If anyone else has any suggestions I'd love to hear them.
If you will detail your solution I could point out any mistakes I see.
Assaf
