How to Find the Centre, Radius, and Interval of Convergence for a Power Series?
  • Thread starter Thread starter danni7070
The discussion revolves around determining the center, radius, and interval of convergence for the power series \(\sum_{n=1}^\infty \frac{1}{n} \frac{(x+2)}{2}^n\). Participants are exploring the mathematical concepts related to power series and convergence criteria.
  • Mixed
  • Participants discuss the method for finding the center and radius of convergence, with some confusion regarding the algebra involved. There are attempts to apply the ratio test and clarify the correct form of the series.
The conversation includes various interpretations of the series and its convergence properties. Some participants have provided guidance on the application of the ratio test, while others are questioning the accuracy of the original problem statement and its implications for the radius of convergence.
There is a noted discrepancy in the transcription of the series, which affects the calculations of the radius of convergence. Participants are also grappling with the implications of the variable \(x\) in their calculations.
danni7070
[Solved] How to calculate.
Determine the centre, radius, and Interval of convergence of the power series.
[tex]\sum_{n=1}^\infty \frac{1}{n} \frac{(x+2)}{2}^n[/tex]
Radius of convergence
[tex]\frac{1}{R} = L = \lim_{n \to {\infty}} \frac{a_n+1}{a_n}[/tex]
so R = 1/L
and the interval is (x-R,x+R)
Finding the centre is easy. x = -2
But the algebra stuff is getting me down. This is where I get confused. I took this from the solution manual and I can't figure out this result.
So we have [tex]R = \lim \frac{2^{n+1}(n+1)}{2^n n} = 2[/tex]
[tex]\frac{1}{R} = L = \lim_{n \to {\infty}} \frac{a_{n+1}}{a_n}[/tex]
Put { } around the "n+1" subscript.
so R = 1/L
Did you copy both the original problem and the solution correctly? In your original formula, that "2" in the denominator was NOT to the n power and so you will NOT have 2n in your ratio. In fact the factors of "2" in both an+1[/sup] and an will cancel and play no part. It should be obvious that
[tex]\sum_{n=1}^\infty \frac{1}{n}\frac{(x+2)^n}{2}[/tex]
is the same as
[tex]\frac{1}{2}\sum_{n=1}^\infty \frac{1}{n}\(x+2)^n[/tex]
so the "1/2" plays no part in the convergence of the series.
You are given that [itex]a_n= (1/n)(x+2)^n[/itex] so [itex]a_{n+1}= (1/(n+1))(x+2)^{n+1}[/itex]. According to the "ratio test", that will converge as long as, in the limit, the ratio of consectutive terms goes to a limit of less than 1. The ratio you want is
[tex]\frac{1}{n+1}\frac{|x+2|^{n+1}}{2}\frac{n}{1}\frac{2}{|x+2|^n}[/tex]
which reduces to
[tex]\frac{n}{n+1}|x+2|}[/tex]
What is the limit of n/(n+1)?
Ok, first of all, thanks for taking time looking at this.
Limit of n/(n+1) is 1
This is exactly what I got. But how is R = 2 then?
Is it right to say that the limit of [tex]\frac{n}{n+1}|x+2|}[/tex] is 2 ?
I don't know what to do with the x in all these calculations.
Now, the limit of [tex]\frac{n}{n+1}|x+2|[/tex] is |x+2|. That will be less than 1 as long as -1< x+2< 1 or =-3< x< -1. The radius of convergence is 1.
That was why I asked if you were sure you had copied everything correctly.
If the problem were, instead,
[tex]\sum_{n=1}^\infty \frac{1}{n}\left(\frac{x+2}{2}\right)^n[/tex]
or (same thing)
[tex]\sum_{n=1}^\infty \frac{1}{n}\frac{(x+2)^n}{2^n}[/itex] <br /> then the radius of convergence would be 2.[/tex]
You are right! I didn't copy the example right!
It is indeed [tex]\sum_{n=1}^\infty \frac{1}{n}\left(\frac{x+2}{2}\right)^n[/tex]
And then of course the radius of convergence is 2 !
Well, thanks a lot HallsofIvy. I'm kinda happy though that I wasn't doing anything wrong in my calculations, just a "small" typo.
Again thanks.
